주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Nintendo 3DS Motherboard Assembly Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. Nintendo 3DS Motherboard Assembly Replacement, Motherboard Assembly: 1 단계, 이미지 1/2 Nintendo 3DS Motherboard Assembly Replacement, Motherboard Assembly: 1 단계, 이미지 2/2
    • Grasp the microphone ribbon cable near the microphone with a pair of tweezers.
    • Pull the microphone straight up out of the upper case.
  2. Nintendo 3DS Motherboard Assembly Replacement: 2 단계, 이미지 1/3 Nintendo 3DS Motherboard Assembly Replacement: 2 단계, 이미지 2/3 Nintendo 3DS Motherboard Assembly Replacement: 2 단계, 이미지 3/3
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the speaker assembly ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, NOT the socket itself. Damaging the socket or cable will result in a 3DS that will blink its power LED when you press the power button - and do nothing else.
    • Disconnect the speaker assembly ribbon cable with a pair of tweezers.
  3. Nintendo 3DS Motherboard Assembly Replacement: 3 단계, 이미지 1/2 Nintendo 3DS Motherboard Assembly Replacement: 3 단계, 이미지 2/2
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the camera ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • When reassembling, note that the gold contacts face toward the motherboard (as opposed to the camera cable's gold contacts facing away).
  4. Nintendo 3DS Motherboard Assembly Replacement: 4 단계, 이미지 1/3 Nintendo 3DS Motherboard Assembly Replacement: 4 단계, 이미지 2/3 Nintendo 3DS Motherboard Assembly Replacement: 4 단계, 이미지 3/3
    • Remove seven Phillips screws securing the motherboard to the upper case:
    • Four 2.5 mm gold screws
    • Two 3.5 mm black screws
    • One 2.5 mm silver screw
    • When you remove this screw the volume slider can fall out.
    • Lift the side of the motherboard that sits along the bottom edge of the 3DS.
  5. Nintendo 3DS Motherboard Assembly Replacement: 5 단계, 이미지 1/3 Nintendo 3DS Motherboard Assembly Replacement: 5 단계, 이미지 2/3 Nintendo 3DS Motherboard Assembly Replacement: 5 단계, 이미지 3/3
    • Continue lifting the motherboard assembly and rotate it until it is resting next to the rest of the device.
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the LCD ribbon cable ZIF socket.
  6. Nintendo 3DS Motherboard Assembly Replacement: 6 단계, 이미지 1/1
    • Remove the motherboard assembly from the rest of the device.
결론
David Hodson
회원 가입일: 04/13/10
150,493 평판
안내서 127개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 1,578
