주요 콘텐츠로 건너뛰기
Nintendo 3DS SD Board Replacement
필요한 것
  1. Nintendo 3DS SD Board Replacement, Loosen the rear screws: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Phillips #00 Screwdriver
    $5.49
    • Use a Phillips PH00 screwdriver to loosen the four screws along the top of the back cover.
    • All screws in this device are JIS screws. Official iFixit PH000-PH1 Phillips screwdrivers are designed to be compatible with JIS screws, so they are safe to use. Using a screwdriver other than an official iFixit screwdriver or a JIS screwdriver may result in stripped screws.
    • The screws are held in place by locking washers, and will not come out of the back cover.
  2. Nintendo 3DS SD Board Replacement, Remove the rear cover: 2 단계, 이미지 2개 중 1개 Nintendo 3DS SD Board Replacement, Remove the rear cover: 2 단계, 이미지 2개 중 2개
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. Nintendo 3DS SD Board Replacement, Battery: 3 단계, 이미지 3개 중 1개 Nintendo 3DS SD Board Replacement, Battery: 3 단계, 이미지 3개 중 2개 Nintendo 3DS SD Board Replacement, Battery: 3 단계, 이미지 3개 중 3개
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
  4. Nintendo 3DS SD Board Replacement, Lower Case: 4 단계, 이미지 1개 중 1개
    • Use a JIS #00 screwdriver to remove the nine 6.3 mm black screws from the lower case.
    • JIS (Japanese Industrial Standards) screws are not the same as Phillips. To avoid stripping these screws, make sure you are using a JIS #00 screwdriver and not a PHILLIPS #00 screwdriver. You can use a PHILLIPS #00 with a lot of downwards force but be warned this will deform the screw head and you risk stripping it.
    • iFixit's Phillips head screwdriver is desinged to reduce damage on JIS head screws so it should be fine to use, still apply more force. Make sure it's iFixit's official Phillips screwdriver as we are unaware of any other manufacturer who does this.
    • Use a JIS #00 screwdriver to remove the 2.4 mm silver screw above the game cartridge slot.
  5. Nintendo 3DS SD Board Replacement: 5 단계, 이미지 3개 중 1개 Nintendo 3DS SD Board Replacement: 5 단계, 이미지 3개 중 2개 Nintendo 3DS SD Board Replacement: 5 단계, 이미지 3개 중 3개
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
  6. Nintendo 3DS SD Board Replacement, SD Board: 6 단계, 이미지 1개 중 1개
    • Remove the two 4.5 mm Phillips screws securing the SD board to the motherboard.
  7. Nintendo 3DS SD Board Replacement: 7 단계, 이미지 2개 중 1개 Nintendo 3DS SD Board Replacement: 7 단계, 이미지 2개 중 2개
    • The connector for the SD board sits underneath the Circle Pad ribbon cable.
    • Use the flat end of a spudger to pry the SD board ribbon cable connector off its socket on the motherboard.
  8. Nintendo 3DS SD Board Replacement: 8 단계, 이미지 3개 중 1개 Nintendo 3DS SD Board Replacement: 8 단계, 이미지 3개 중 2개 Nintendo 3DS SD Board Replacement: 8 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger between the SD board and the motherboard.
    • Run the spudger along the sides of the SD board to free it from the adhesive pad holding it in place.
    • Once completely freed, lift the SD board straight off the motherboard.
결론
다른 22명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
David Hodson
회원 가입일: 04/13/10
154,622 평판
안내서 127개를 작성함
12가이드 댓글
Where can i purchase the sd card board replacement part? Does amazon carry them?
Jen - 답글
You can usually find them on ebay to around $3 to $6 dollars (non oem and oem)
David Vokas -
Is there a way to do this with the older 3ds xl version? I didn't see any screws holding the sd board in when I opened it up.
NickySeley - 답글
Would this work for my problem? My problem is that the SD Card won't stay in, it just pops back out. Would this method still work? I'm not that experienced or knowledgeable about fixing these sort of things, so I'm not sure if the spring is part of it or not, lol. Also, where could I buy an SD Card board replacement part for cheap in Canada?
Caitlin Lumsden - 답글
Usually that is the locking mechanism, you can replace the SD card slot for around $6 or $3 if you buy the non oem part.
David Vokas -
댓글 쓰기
조회 통계:
지난 24시간: 22
지난 7일: 113
지난 30일: 532
전체 시간: 34,065
