소개
Can't hear anything through your speakers? Even worse, are they stuck on full volume? You might need a new volume switch.
부품
지정된 부품이 없습니다.
Insert a plastic opening tool into the notch in the lower case above the battery.
Pry the battery up with the plastic opening tool.
Grab the top edge of the battery and lift it out of the lower case.
Remove the nine 6.3 mm black Phillips screws from the lower case.
Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
Remove the two 7.7 mm Phillips screws securing the back of the Circle Pad to the motherboard.
Slide the flat end of a spudger under the corner of the Wi-Fi board, and lift it away from the motherboard.
Grasp the microphone ribbon cable near the microphone with a pair of tweezers.
Pull the microphone straight up out of the upper case.
Use the flat end of a spudger to pry the volume switch connector out of its socket on the motherboard.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 2개
What are all the tools I'd need to complete this repair? And where can I buy them?
