주요 콘텐츠로 건너뛰기
부품
  1. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    : step 1, image 1 of 1
    • Unscrew the four Phillips #00 screws along the top of the back cover.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    • The comments section is full of unlucky souls who will tell you that the screws here through step 4 will strip incredibly easily. Press down fairly hard, and go slow.
  2. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    : step 2, image 1 of 2 : step 2, image 2 of 2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    : step 3, image 1 of 3 : step 3, image 2 of 3 : step 3, image 3 of 3
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
  4. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    : step 4, image 1 of 1
    • Remove the nine 6.3 mm black Phillips screws from the lower case.
    • These screws will strip very easily unless you use the correct size bit. Apply pressure to the screws while turning to avoid stripping them.
    • Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
  5. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    : step 5, image 1 of 3 : step 5, image 2 of 3 : step 5, image 3 of 3
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
  6. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    : step 6, image 1 of 2 : step 6, image 2 of 2
    • Slide the flat end of a spudger under the corner of the Wi-Fi board, and lift it away from the motherboard.
    • The Wi-Fi antenna cable is still connected to the Wi-Fi board, so you cannot completely remove the Wi-Fi board yet.
  7. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    : step 7, image 1 of 2 : step 7, image 2 of 2
    • Lift the Wi-Fi board off the motherboard and rotate it so that the bottom side is facing up.
    • Use the flat end of a spudger to pry the Wi-Fi antenna cable connector off its socket on the Wi-Fi board.
    • Remove the Wi-Fi board from the 3DS.
결승점
다른 12명이 해당 안내서를 완성하였습니다.
David Hodson
회원 가입일: 2010년 04월 13일
146,665 평판
안내서 127개 작성하였습니다
댓글 8개
I know someone who needs to have the wifi card removed from their DS for multiple reasons. If these steps are followed and the card is just removed will the 3DS still work to play games? They want to use it to play games only and do not want access to the internet.
brwnsrule - 답글
Did this job, but the wireless is still not working. Any suggestions?
tech man - 답글
Get a new wi-fi card. That is the only thing I have found to work.
afdflol82 -
will a 3ds xl wireless card fit within a 3ds? I am on Ebay looking to buy a replacement part but i can't find a proper replacement.
Daniel Garcia - 답글
Hi David, i know this is an older guide, but you just saved me from buying a new 3DS. The wifi board had come lose in a drop, with your help i managed to reattach it and bring it back into working condition.
Thank you!
Michael Friis - 답글
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 87
30일 전: 383
전체 시간: 33,950
