주요 콘텐츠로 건너뛰기
Nintendo 3DS XL 2015 Upper Screen Replacement
필요한 것
  1. Nintendo 3DS XL 2015  Upper Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Ensure your device is powered off before proceeding. Failure to do so may result in electrical shock or damage to the device.
    • Place the 3DS upside down. Remove the game card, headphones, charging cable, stylus, or anything else that may be connected to the device.
  2. Nintendo 3DS XL 2015  Upper Screen Replacement: 2 단계, 이미지 1/1
    • Using a JIS #0 screwdriver, loosen the two black screws on the back.
    • The screws are held in place by captive washers and should not be completely removed.
  3. Nintendo 3DS XL 2015  Upper Screen Replacement: 3 단계, 이미지 1/1
    • Once the screws are loosened, pry open the back cover.
  4. Nintendo 3DS XL 2015  Upper Screen Replacement: 4 단계, 이미지 1/1
    • The battery is located on the left hand side of the 3DS - to remove, use the small gap located at the top-middle and pull up with a non metal pointed tool.
  5. Nintendo 3DS XL 2015  Upper Screen Replacement, Motherboard: 5 단계, 이미지 1/1
    • Using a JIS #000 screwdriver, remove the six 6mm screws around the edges of the secondary cover.
  6. Nintendo 3DS XL 2015  Upper Screen Replacement: 6 단계, 이미지 1/2 Nintendo 3DS XL 2015  Upper Screen Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using tweezers, carefully pop out the rubber bumpers located at the top side of the 3DS. Removing them will reveal another two 6mm screws. Remove these screws using a JIS #000 as well.
  7. Nintendo 3DS XL 2015  Upper Screen Replacement: 7 단계, 이미지 1/3 Nintendo 3DS XL 2015  Upper Screen Replacement: 7 단계, 이미지 2/3 Nintendo 3DS XL 2015  Upper Screen Replacement: 7 단계, 이미지 3/3
    • To separate the cover, carefully lift it up and away from the hinges (in order to clear the headphone port), then pivot it towards the hinges to expose the circuit boards.
    • Don't fully remove the cover yet, or you may damage the delicate ribbon cable that still connects it to the motherboard.
  8. Nintendo 3DS XL 2015  Upper Screen Replacement: 8 단계, 이미지 1/1
    • Use a pair of tweezers to lift away the two plugs that latch the L/R/ZL/ZR button ribbons to the motherboard. You can now remove the back cover completely and set it aside.
  9. Nintendo 3DS XL 2015  Upper Screen Replacement: 9 단계, 이미지 1/1
    • Use tweezers to flip up the small, hinged locking flap in order to unlock the ZIF connector securing the circle pad ribbon.
    • Slide the ribbon out of the ZIF connector.
  10. Nintendo 3DS XL 2015  Upper Screen Replacement: 10 단계, 이미지 1/1
    • Using a JIS #000 screwdriver, remove the two 8 mm screws securing the circle pad.
  11. Nintendo 3DS XL 2015  Upper Screen Replacement: 11 단계, 이미지 1/1
    • Lift the circle pad casing upward to remove it. There will be some friction, but it should not require excessive force.
  12. Nintendo 3DS XL 2015  Upper Screen Replacement: 12 단계, 이미지 1/1
    • Locate the gold terminal plug with a red cable at the top left of the motherboard. Using your fingers, carefully pull the plug straight upward to remove.
    • Use a pair of tweezers to disconnect the single ribbon connector.
    • Don't do what we did -- be very careful not to pull on the red cable.
  13. Nintendo 3DS XL 2015  Upper Screen Replacement: 13 단계, 이미지 1/3 Nintendo 3DS XL 2015  Upper Screen Replacement: 13 단계, 이미지 2/3 Nintendo 3DS XL 2015  Upper Screen Replacement: 13 단계, 이미지 3/3
    • Using tweezers, gently pull the five marked ribbons out of the ZIF connectors along the sides of the motherboard.
    • These ZIF connectors are held in place by friction and do not have locks—lifting the flaps on these connectors will break them! Note that in some models the upper-most connector may have a lock.
    • Three of the ribbon connectors have plastic clamping flaps that cover the ribbon to prevent slippage. Use the tweezers to flip them up before ribbon removal.
    • When reassembling the device, be sure to flip the ZIF clamps back down.
    • While the SD card reader is shown as removed in this photo, it is optional for the removal of the motherboard.
  14. Nintendo 3DS XL 2015  Upper Screen Replacement: 14 단계, 이미지 1/1
    • Using a JIS #000 screwdriver, remove six 4mm screws along the edges of the motherboard.
  15. Nintendo 3DS XL 2015  Upper Screen Replacement: 15 단계, 이미지 1/2 Nintendo 3DS XL 2015  Upper Screen Replacement: 15 단계, 이미지 2/2
    • Carefully pivot the motherboard 90 degrees toward the hinges to reveal two more ZIF connectors on the underside of the motherboard.
    • Both have latches that must be flipped up. The left, longer latch is black; the right, shorter one is white. Flip up the flaps, slide the ribbons out and remove the motherboard.
    • Note which way the ribbons slide into their connectors carefully, as they are different.
  16. Nintendo 3DS XL 2015  Upper Screen Replacement, Top Display Casing: 16 단계, 이미지 1/2 Nintendo 3DS XL 2015  Upper Screen Replacement, Top Display Casing: 16 단계, 이미지 2/2
    • Using a 1.5 flat head, remove the four red rubber stickers that are on the inside of the casing.
    • Underneath the rubber is a silver sticky
    • Using the PH00 screw driver, remove the screws.
  17. Nintendo 3DS XL 2015  Upper Screen Replacement: 17 단계, 이미지 1/2 Nintendo 3DS XL 2015  Upper Screen Replacement: 17 단계, 이미지 2/2
    • From the hinge, slide the outer portion of the top shell so that it separates from the inner portion.
    • This step was edited recently because the previous version was risky. It told people to use a spudger and slide it around the edges. DO NOT DO THIS!!! It will snap tabs off!
    • The casing will become loose, and just lift the casing off.
  18. Nintendo 3DS XL 2015  Upper Screen Replacement, Upper Screen: 18 단계, 이미지 1/2 Nintendo 3DS XL 2015  Upper Screen Replacement, Upper Screen: 18 단계, 이미지 2/2
    • Make sure that all the taped parts are untaped from the screen and moved onto the side.
    • Using a plastic spudger, slightly lift it from underneath the lips and move it around the screen.
    • Once it is loose, lift the screen carefully.
  19. Nintendo 3DS XL 2015  Upper Screen Replacement: 19 단계, 이미지 1/1
    • The cables to the LCD are attached to the lower part of the 3DS' motherboard.
    • Be careful to avoid pulling the cables through the 3DS to prevent further damage.
    • Make sure to replace all cables to the correct location.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Ryan Butler
회원 가입일: 02/09/16
1,695 평판
안내서 9개 작성하였습니다
iFixit, Team 1-1, Weber Winter 2016 iFixit, Team 1-1, Weber Winter 2016 회원
FIX-WEBER-W16S1G1
4 회원들
안내서 37개 작성하였습니다
댓글 10개
I am lost, where is the rest of the guide?
Jo Jones - 답글
Is it possible we could get a link to a screen replacement?
Rupin Soland - 답글
Almost every guide on the internet skips over getting ribbon-cable through the hinge…
Devin Shrhs - 답글
and its the step that gets messed up the most so that may be why since you have to roll up the ribbon to get it through the hinge giving it a good chance of breaking the ribbon. Sucks because the only way to tell is to hook it all back up to see if it worked.
Jacob -
This guide is WORTHLESS - it’s ''cut-out in the middle'' at step 19 and in the most important part (ribbons)!!! I’ll make my own guide (possibly this year) This is a joke…
Sebastian - 답글
댓글 쓰기
조회 통계:
24 시간 전: 29
7일 전: 231
30일 전: 933
전체 시간: 34,846
