주요 콘텐츠로 건너뛰기
Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement
필요한 것
  1. Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement, Battery: 1 단계, 이미지 1/1
    • Ensure your device is powered off before proceeding. Failure to do so may result in electrical shock or damage to the device.
    • Place the 3DS upside down. Remove the game card, headphones, charging cable, stylus, or anything else that may be connected to the device.
  2. Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 2 단계, 이미지 1/1
    • Using a JIS #0 screwdriver, loosen the two black screws on the back.
    • The screws are held in place by captive washers and should not be completely removed.
    My experience indicates that a JIS #1 is more appropriate here.
    John Menden - 답글
    Same here, much more appropriate.
    Jack Wilson -
  3. Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 3 단계, 이미지 1/1
    • Once the screws are loosened, pry open the back cover.
  4. Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 4 단계, 이미지 1/1
    • The battery is located on the left hand side of the 3DS - to remove, use the small gap located at the top-middle and pull up with a non metal pointed tool.
    Also you should remove any SD card at this point
    James Grant - 답글
    Does this battery work on a NEW 3DS XL model?
    Froggy The Frog - 답글
    This guide is for the New 3DS XL, which is called the 2015 3DS XL here on iFixit. If you're asking about the 3DS replacement battery advertised in the iFixit store, I believe it works for both new and old models.
    BabblingFishes -
  5. Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement, A,B,X,Y, Start or Select Button: 5 단계, 이미지 1/1
    • Remove six 6mm screws on secondary panel using a JIS #000 screwdriver.
    the heck. on step 5 im using the 000 screwdriver from the kit and i am destroying the screw, yes going counter clockwise.
    the j000 and 000 don't work. im using the toolkit from your site and i don't see a JIS #000 just J000 and 000
    edit: so the j00 works.
    stephankranenfeld - 답글
  6. Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 6 단계, 이미지 1/2 Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 6 단계, 이미지 2/2
    • Remove two upper rubber bumpers locates on either side of the charging port.
    • Using JIS #00 screwdriver, carefully remove the two 6mm screws that have now been exposed.
    A #0 worked better for me than the #00
    Lucas M - 답글
    All 8 screws from Step 5 to 6 are the same size and should be pulled out using a #000 screwdriver.
    Alan Chen - 답글
  7. Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 7 단계, 이미지 1/3 Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 7 단계, 이미지 2/3 Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 7 단계, 이미지 3/3
    • To pry off the cover, carefully lift it up and away from the hinges (in order to clear the headphone port), then pivot it towards the hinges to expose the circuit boards.
  8. Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 8 단계, 이미지 1/1
    • Use non-conductive tweezers to disconnect the two ribbon plugs that connect the L/R/ZL/ZR buttons on the cover to the motherboard, then remove it completely.
  9. Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 9 단계, 이미지 1/3 Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 9 단계, 이미지 2/3 Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 9 단계, 이미지 3/3
    • Locate the ribbon connector between the motherboard and the left circuit board (it should be the widest) and use a pair of tweezers to pivot up the ZIF clasp upward.
    • The ribbon can be removed using non-conductive tweezers by pulling out parallel with the board.
  10. Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 10 단계, 이미지 1/1
    • Next, locate the five 3mm screws on the left board and remove them using a JIS #000 screwdriver.
  11. Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 11 단계, 이미지 1/1
    • Carefully flip the board over and use tweezers to remove the blue-black ribbon located underneath.
    Closely examine the connection before removing the ribbon from the board!
    The C-stick ribbon is secured to the action board at the socket by a black tab that must be unlocked (swiveled up) before the ribbon is free to be removed. Yanking the ribbon from the locked connector may break off the lock and you'll be forced to replace the entire board.
    The easier way to do this is to leave this ribbon connected. Go back to Step 10 and remove the three black screws securing the C-stick unit to the frame. Remove the C-stick unit along with the board and move onto Step 12.
    THRILLHOUSE - 답글
  12. Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 12 단계, 이미지 1/1
    • Remove the gray rubber diamond to reveal the A/B/X/Y buttons and/or the rubber rectangle to reveal the Start/Select button.
    • Remove the buttons using tweezers.
    • When replacing, be sure to check that each button is placed back and is snugly fit into the appropriate hole before reassembling the device.
    It would be good to show photos how to carefully peel off the membrane, so that the contacts can be cleaned, or replaced. This is shown in white on the PCB on photo 11. I put further details further down where someone asked a question. This applies to other 3DS models too
    Andrew - 답글
결론
다른 24명이 해당 안내서를 완성하였습니다.
Kobbe Farwick
회원 가입일: 04/01/15
2,133 평판
안내서 2개 작성하였습니다
Cal Poly, Team 24-4, Lancaster Spring 2015 Cal Poly, Team 24-4, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S24G4
4 회원들
안내서 25개 작성하였습니다
댓글 10개
do the smaller new 3ds colored buttons work in the new 3ds xl?
itsandy14 - 답글
It will work, since the only difference between them is the size of screen and shell, but size of buttons and other pieces should be of the same.
CheatJoker -
If anyone else comes on this, I can confirm the small 3ds buttons do not quite work right they are slightly smaller and the cut outs that keep the buttons from spinning around are not the same
Mark Damien English -
Can someone provide further information about replacement of the entire C stick?
Or is it just as simple as pull the ribbon carefully, take the old one out and put the new one in?
CheatJoker - 답글
The set of screws on the secondary panel are giving me trouble. I think I might be stripping them... Is it normal for them to be screwed on so tight? I don't want to pay 85 bucks just because I need to press my B button harder to make it work...
Ben Fuqua - 답글
One of the screw of the second set was also giving me trouble. Just press firmly and turn very slowly. As they are not supposed to be touched by the consumer, I suspect they put a kind of sealant to make them harder to unscrew.
Alex Lebeau -
One thing to note is that the kit that I received from ifixit had the c-stick nub attached to the board. As such, you'll want to remove the c-stick instead of disconnecting the ribbon.
Jason Thompson - 답글
Would be cool to provide in every section a place where users can offer a paid service to repair devices other users are afraid to repair.
theoctopusride - 답글
Does annyone know what is wrong with my new 3ds xl... So all buttons work fine BUT the a button needs alot of pressure to work. Tried to clean it but idk still needs way more pressure than the rest…
TMHate MK - 답글
I had the same problem, the A button especially was very temperamental and had to push it very hard to trigger. I watched a video yesterday which showed carefully peeling the transparent membrane off with tweezers to get inside the metal domes (it's very sticky so was difficult to get it to start peeling, but comes away carefully once you manage to get it started, just don't peel too hard that it rips). This is what holds the 4 metal domes in place. I then cleaned them as there was slight corrosion in there. I then pushed the membrane down and reassembled where it now works perfectly. I then did the same with the D-pad which worked but didn't always trigger when it clicked but would it you pushed them slightly harder and they are working perfectly.
One tip, if possible, don't completely remove the transparent membrane. just peel it enough to gain access, so you can push back down .if you peel it completely you'll have to realign it perfectly, and if it doesn't line up they won't work. The tolerance is tight!
Andrew -
댓글 쓰기
조회 통계:
24 시간 전: 19
7일 전: 141
30일 전: 762
전체 시간: 40,067
