주요 콘텐츠로 건너뛰기
Nintendo 3DS XL 2015 Battery Replacement
필요한 것
  1. Nintendo 3DS XL 2015 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Ensure your device is powered off before proceeding. Failure to do so may result in electrical shock or damage to the device.
    • Place the 3DS upside down. Remove the game card, headphones, charging cable, stylus, or anything else that may be connected to the device.
  2. Nintendo 3DS XL 2015 Battery Replacement: 2 단계, 이미지 1/1
    • Using a JIS #0 screwdriver, loosen the two black screws on the back.
    • The screws are held in place by captive washers and should not be completely removed.
    My experience indicates that a JIS #1 is more appropriate here.
    John Menden - 답글
    Same here, much more appropriate.
    Jack Wilson -
  3. Nintendo 3DS XL 2015 Battery Replacement: 3 단계, 이미지 1/1
    • Once the screws are loosened, pry open the back cover.
  4. Nintendo 3DS XL 2015 Battery Replacement: 4 단계, 이미지 1/1
    • The battery is located on the left hand side of the 3DS - to remove, use the small gap located at the top-middle and pull up with a non metal pointed tool.
    Also you should remove any SD card at this point
    James Grant - 답글
    Does this battery work on a NEW 3DS XL model?
    Froggy The Frog - 답글
    This guide is for the New 3DS XL, which is called the 2015 3DS XL here on iFixit. If you're asking about the 3DS replacement battery advertised in the iFixit store, I believe it works for both new and old models.
    BabblingFishes -
결론
다른 28명이 해당 안내서를 완성하였습니다.
Kobbe Farwick
회원 가입일: 04/01/15
2,145 평판
안내서 2개 작성하였습니다
Cal Poly, Team 24-4, Lancaster Spring 2015 Cal Poly, Team 24-4, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S24G4
4 회원들
안내서 25개 작성하였습니다
댓글 3개
Bonjour,
Tout d’abord merci pour ces explications claires et précises. Toutefois, je me demandais s’il y avait un endroit où l’on peut trouver une batterie officielle Nintendo ? Après quelque recherches je n’ai malheureusement rien trouvé (et comme la console est vieillissante…)?
Nicolas BARET - 답글
Bonjour Nicolas Si vous voulez une pièce de nintendo, vous devez être en amérique ou au canada car nintendo ne vend des pièces que dans ces pays, je peux vous donner le site Web pour les états-unis et le canada si vous le souhaitez.
Nelson Berrios -
댓글 쓰기
조회 통계:
24 시간 전: 13
7일 전: 95
30일 전: 516
전체 시간: 16,313
