소개
If the game card reader is malfunctioning due to any issues (such as broken connection and/or unresponsive behavior), this replacement guide will help you replace the it.
필요한 것
Place the 3DS upside down. Remove the game card, headphones, charging cable, stylus, or anything else that may be connected to the device.
Using a JIS #000 screwdriver, remove the six 6mm screws around the edges of the secondary cover.
Use tweezers to flip up the small, hinged locking flap in order to unlock the ZIF connector securing the circle pad ribbon.
Slide the ribbon out of the ZIF connector.
Carefully pivot the motherboard 90 degrees toward the hinges to reveal two more ZIF connectors on the underside of the motherboard.
Both have latches that must be flipped up. The left, longer latch is black; the right, shorter one is white. Flip up the flaps, slide the ribbons out and remove the motherboard.
Remove five 5mm screws from the game card reader panel using a JIS #000 screwdriver.
The game card reader can now be removed and replaced.
다른 15명이 해당 안내서를 완성하였습니다.
댓글 9개
I bought a replacement card slot and it has the small flat cable connector not on the top right like on your photos (and in my New 3DS XL) but on the right oriented to the right, see https://abload.de/img/cardslot_sintech_2....
Does anyone have any insight on different revisions of the card slot? Where can I buy a card slot like the one in the photos here? Thanks in advance.
You don't have to take the entire board out to replace this
Are you sure?
That is true. I just changed mine easily without removing the whole mainboard..
