주요 콘텐츠로 건너뛰기
Nintendo 3DS XL Battery Replacement
필요한 것
  1. Nintendo 3DS XL Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Nintendo 3DS XL Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Loosen the two #00 Phillips 4.2 mm-length screws located at the top of the back cover.
    • The screws have locking washers that prevent the screws from falling off of the back cover. Leave these locking washers on the screws; it is not necessary to remove the washers for this repair guide.
  2. Nintendo 3DS XL Battery Replacement: 2 단계, 이미지 2개 중 1개 Nintendo 3DS XL Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Hold the device so that the cover is facing up.
    • Using a plastic opening tool, pry off the cover starting at the top right corner.
    • Hold the edge of the cover to ensure it does not reattach.
    • Look for the small section below the stylus compartment. Pry off the cover at that point if it is still attached.
    • Take off the cover of the device and set it aside.
  3. Nintendo 3DS XL Battery Replacement: 3 단계, 이미지 3개 중 1개 Nintendo 3DS XL Battery Replacement: 3 단계, 이미지 3개 중 2개 Nintendo 3DS XL Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool into the opening located on the right side of the battery.
    • Pry off the battery from the lower casing.
    • Lift the battery out of the case and set aside.
결론
다른 52명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Charlene Donlon
회원 가입일: 04/08/14
10,610 평판
안내서 8개를 작성함
Cal Poly, Team 9-13, Regan Spring 2014 Cal Poly, Team 9-13, Regan Spring 2014 회원
CPSU-REGAN-S14S9G13
5 회원들
안내서 44개를 작성함
댓글 6개
Time estimate: 3 - 9 hours Difficulty: Very difficult ??????
More like 30-90 seconds, and that's if you have to search for a screwdriver.
Tommy Lynch - 답글
机器无法开机怎么办?是电池的问题吗?
doanaruto - 답글
It should be noted that the bottom three clips on the bottom of the backplate can’t just be snapped in, they need to be slipped in, so when removing the backplate, it should be tiled away from the system and then pulled up from the bottom, and those three clips on the bottom should be the first clips in when you’re putting it back together, sliding them in with the backplate at an angle, and then the rest of the clips just snap in.
Cole Jackson - 답글
Just did this. For reasmbly I recommend putting the bottom/lower part of the case on first before you screw it back on.
Scott Vogel - 답글
댓글 쓰기
조회 통계:
지난 24시간: 54
지난 7일: 394
지난 30일: 1,657
전체 시간: 62,720
