주요 콘텐츠로 건너뛰기
Nintendo 3DS XL Left Bumper Replacement
필요한 것
  1. Nintendo 3DS XL Left Bumper Replacement, Left Bumper: 1 단계, 이미지 1/1
    • Remove the SD card and the game cartridge from the device.
  2. Nintendo 3DS XL Left Bumper Replacement, Battery removal: 2 단계, 이미지 1/2 Nintendo 3DS XL Left Bumper Replacement, Battery removal: 2 단계, 이미지 2/2
    • Locate the battery cover panel on the back of the device.
    • Unscrew the two screws on the battery cover panel with a Phillips #00 screwdriver.
    • Remove the battery and battery cover panel.
  3. Nintendo 3DS XL Left Bumper Replacement: 3 단계, 이미지 1/1
    • Remove the four screws on the battery panel using the Phillips #00 screwdriver.
  4. Nintendo 3DS XL Left Bumper Replacement: 4 단계, 이미지 1/1
    • Locate the two screw covers on the bottom of the back panel, near the middle of the device.
    • These sticker-like covers are small, round, and made of rubber or plastic.
    • Insert the tip of a flathead screwdriver or spudger and gently pry the cover off by applying upward pressure.
    • You may need to wiggle the tool back and forth a bit to loosen the two covers.
    • Remove the two screws located behind the screw covers using a Phillips #00 screwdriver.
  5. Nintendo 3DS XL Left Bumper Replacement: 5 단계, 이미지 1/2 Nintendo 3DS XL Left Bumper Replacement: 5 단계, 이미지 2/2
    • Remove the screw near the game card compartment using a Phillips #00 screwdriver.
  6. Nintendo 3DS XL Left Bumper Replacement: 6 단계, 이미지 1/2 Nintendo 3DS XL Left Bumper Replacement: 6 단계, 이미지 2/2
    • Lift the back panel off of the device.
    • Be cautious not to pull any ribbons or cables from the motherboard as you remove the back panel.
    • Locate and disconnect the ribbon cables from the motherboard by gently pulling on the tabs that hold them in place.
  7. Nintendo 3DS XL Left Bumper Replacement: 7 단계, 이미지 1/2 Nintendo 3DS XL Left Bumper Replacement: 7 단계, 이미지 2/2
    • Remove the three left bumper assembly screws using Phillips #00 screwdriver.
    • Once the three screws are removed, gently remove the left bumper assembly from the device.
    • The spring may eject from the assembly as you remove it.
    • Remove the hinge pin from the bumper assembly.
  8. Nintendo 3DS XL Left Bumper Replacement: 8 단계, 이미지 1/1
    • Separate the bumper from the bumper assembly
  9. Nintendo 3DS XL Left Bumper Replacement: 9 단계, 이미지 1/2 Nintendo 3DS XL Left Bumper Replacement: 9 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    구매
    • Using a spudger or a flathead screwdriver, gently pull the ribbon cable straight out of the connector in order to remove it.
    • The ribbon cable can be removed by other means such as using gloves or a microfiber cloth if preferred.
    • Replace the left bumper ribbon cable.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jack Belcher
회원 가입일: 10/26/21
187 평판
안내서 1개 작성함
University of North Texas, Team 3-1, Thomas Fall 2021 University of North Texas, Team 3-1, Thomas Fall 2021 회원
UNT-THOMAS-F21S3G1
4 회원들
안내서 3개 작성하였습니다
댓글 3개
No steps on how to install the new bumper?
Alex Tomalty - 답글
good but i wish there were reinstall instructions
Rowan Webb - 답글
I think that it's just basically do the steps backwards then you have it fixed.
Ender - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 41
30일 전: 256
전체 시간: 5,583
