주요 콘텐츠로 건너뛰기
Nintendo 64 Bottom Cover Disassembly
필요한 것
  1. Nintendo 64 Bottom Cover Disassembly, Top Cover: 1 단계, 이미지 1/1
    • Remove the expansion pack cover by pushing in the tab and pulling out.
  2. Nintendo 64 Bottom Cover Disassembly: 2 단계, 이미지 1/1
    • If your system uses a jumper pack, the same procedure applies to remove it.
    • A small spoon can be used in place of a spudger.
    • Lever the expansion pack out using a metal spudger.
  3. Nintendo 64 Bottom Cover Disassembly: 3 단계, 이미지 1/1
    • Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
  4. Nintendo 64 Bottom Cover Disassembly: 4 단계, 이미지 1/1
    • Remove the two front feet of the N64.
  5. Nintendo 64 Bottom Cover Disassembly: 5 단계, 이미지 1/1
    • Rotate to top side up and lift off top cover.
  6. Nintendo 64 Bottom Cover Disassembly, Metal Plate: 6 단계, 이미지 1/2 Nintendo 64 Bottom Cover Disassembly, Metal Plate: 6 단계, 이미지 2/2
    • Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
  7. Nintendo 64 Bottom Cover Disassembly: 7 단계, 이미지 1/2 Nintendo 64 Bottom Cover Disassembly: 7 단계, 이미지 2/2
    • Remove the metal plate indicated in the example by sliding it back and then lifting it up.
  8. Nintendo 64 Bottom Cover Disassembly: 8 단계, 이미지 1/1
    • Remove the two screws indicated in the example using the smaller Phillips screwdriver.
  9. Nintendo 64 Bottom Cover Disassembly: 9 단계, 이미지 1/1
    • Remove the screw to the right of the LED light using the larger Phillips screwdriver.
  10. Nintendo 64 Bottom Cover Disassembly: 10 단계, 이미지 1/1
    • Remove the small metal bracket from the back of the expansion pack slot.
  11. Nintendo 64 Bottom Cover Disassembly: 11 단계, 이미지 1/2 Nintendo 64 Bottom Cover Disassembly: 11 단계, 이미지 2/2
    • Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
  12. Nintendo 64 Bottom Cover Disassembly: 12 단계, 이미지 1/2 Nintendo 64 Bottom Cover Disassembly: 12 단계, 이미지 2/2
    • Remove the small metal bracket behind the expansion slot using the spudger.
  13. Nintendo 64 Bottom Cover Disassembly: 13 단계, 이미지 1/2 Nintendo 64 Bottom Cover Disassembly: 13 단계, 이미지 2/2
    • Remove the seven screws indicated in the example using the larger Phillips screwdriver.
  14. Nintendo 64 Bottom Cover Disassembly: 14 단계, 이미지 1/1
    • Lift off and remove the metal plate as indicated in the example.
  15. Nintendo 64 Bottom Cover Disassembly, Motherboard: 15 단계, 이미지 1/1
    • Remove the four screws indicated using the #1 Phillips screwdriver.
  16. Nintendo 64 Bottom Cover Disassembly, Motherboard removal: 16 단계, 이미지 1/1
    • Lift up and remove the motherboard.
  17. Nintendo 64 Bottom Cover Disassembly, Nintendo 64 Bottom Cover Disassembly: 17 단계, 이미지 1/1
    • Remove everything from the bottom cover.
결론
다른 23명이 해당 안내서를 완성하였습니다.
tonymag28
회원 가입일: 10/28/09
2,154 평판
안내서 3개 작성하였습니다
Cal Poly, Team 5-4, Regan Fall 2009 Cal Poly, Team 5-4, Regan Fall 2009 회원
CPSU-REGAN-F09S5G4
7 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 42
30일 전: 162
전체 시간: 40,063
