소개
This guide will show how to replace the Nintendo 64 motherboard.
부품
지정된 부품이 없습니다.
Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
I’m not entirely certain if it's a common difference, but my nintendo 64 doesn’t have fourteen screws, but rather, 8 screws, and instead of 3 heat sinks, it only has the one separate heat sink on the chip close to the memory expansion pack. additionally, aside from the 6 screws closest to the expansion pack, the two other screws are held on by nuts under the metal piece.
Remove the four screws indicated using the #1 Phillips screwdriver.
다른 34명이 해당 안내서를 완성하였습니다.
