주요 콘텐츠로 건너뛰기
Nintendo DS Lite Battery Disconnect
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. Nintendo DS Lite Battery Disconnect, Nintendo DS Lite Battery Disconnect: 1 단계, 이미지 1/1
    • Place your device upside down and locate the battery compartment.
    • Find the Phillips head screw securing the battery cover in the bottom right hand corner of the device.
    • Loosen the screw enough to remove the battery cover but leave the screw in the cover for reassembly.
    • Use only a Phillips screwdriver to remove screw.
  2. Nintendo DS Lite Battery Disconnect: 2 단계, 이미지 1/1
    • Slowly remove the battery cover with the iFixit opening tool.
    • Make sure to remove the cover carefully to keep from losing Phillips screw in the cover. It will be needed for reassembly.
  3. Nintendo DS Lite Battery Disconnect: 3 단계, 이미지 1/2 Nintendo DS Lite Battery Disconnect: 3 단계, 이미지 2/2
    • Use the iFixit opening tool to carefully pry the battery out of the case.
    • After the old battery is removed replace it with a new battery facing the same direction as when the cover was opened.
    • For some devices, you may be able to remove the battery by flipping the DS over and letting the battery fall into your hand.
결론
To replace battery and reassemble your device, follow these instructions in reverse.
다른 2명이 해당 안내서를 완성하였습니다.
Brittany K
회원 가입일: 01/21/10
1,484 평판
안내서 4개 작성하였습니다
Cal Poly, Team 16-30, Maness Winter 2010 Cal Poly, Team 16-30, Maness Winter 2010 회원
CPSU-MANESS-W10S16G30
4 회원들
안내서 25개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 12
전체 시간: 5,661
