주요 콘텐츠로 건너뛰기
Nintendo DS Lite Battery Replacement
필요한 것
  1. Nintendo DS Lite Battery Replacement, Battery: 1 단계, 이미지 1/2 Nintendo DS Lite Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Unscrew the Phillips screw securing the battery cover to the lower case.
    • The screw remains captive to the battery cover.
    • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
  2. Nintendo DS Lite Battery Replacement: 2 단계, 이미지 1/1
    • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
    • Remove the battery from the DS Lite.
결론
다른 46명이 해당 안내서를 완성하였습니다.
Matthew Newsom
회원 가입일: 01/05/10
39,726 평판
안내서 67개 작성하였습니다
댓글 5개
Can you describe the type of screw and captive washer ?
Cornel Paraschiv - 답글
Thank you.
i just ordered a new battery as I already got a new power cord & it won’t charge at all.
Hoping new battery does the trick.
Thanks again.
T. Kellogg
Tamela Kellogg - 답글
Thanks but will a dsi battery work
Zach - 답글
My battery cover won’t come off.
Jake - 답글
Flip the console upside down and it will but don’t pull it will break hold it close to the console then slide it back
dead -
댓글 쓰기
조회 통계:
24 시간 전: 19
7일 전: 163
30일 전: 676
전체 시간: 55,447
