소개
Has your DS Lite battery stopped providing the game time you deserve? Replace the battery to free yourself from the wall charger.
필요한 것
Unscrew the Phillips screw securing the battery cover to the lower case.
Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
다른 46명이 해당 안내서를 완성하였습니다.
댓글 5개
Can you describe the type of screw and captive washer ?
Thank you.
i just ordered a new battery as I already got a new power cord & it won’t charge at all.
Hoping new battery does the trick.
Thanks again.
T. Kellogg
A Phillips #000 (PH000) seems to give a more secure fit (no slipping) than the stated Phillips #00.
Ritchie - 답글
This will be good for mods
Matthew Bevins - 답글
I'm having a problem getting the screw to unscrew. I have the right Phillips ( it was included with all the stuff I got this) Any tips. it doesn't look like the screw is spinning but i haven't played my Nintendo DS Lite for 3 years.
whittlegirls - 답글
bonjour j’ai une petite question pour vous fais trés longtemps que j’ai pas utiliser mon nintendo ds lite et quand je le branche il allume 1 fois orange après il s’enteint même s’il est brancher ça veux tu dire qu’il faut que je change de batterie ? Merci
Marie-Julie Richer - 답글
Soit un changement de batterie, soit la carte-mère a peut-être un court-circuit :/
Polaris -
