주요 콘텐츠로 건너뛰기
Nintendo DS Lite Battery Replacement
필요한 것
  1. Nintendo DS Lite Battery Replacement, Battery: 1 단계, 이미지 1/2 Nintendo DS Lite Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Unscrew the Phillips screw securing the battery cover to the lower case.
    • The screw remains captive to the battery cover.
    • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
    A Phillips #000 (PH000) seems to give a more secure fit (no slipping) than the stated Phillips #00.
    Ritchie - 답글
    This will be good for mods
    Matthew Bevins - 답글
    I'm having a problem getting the screw to unscrew. I have the right Phillips ( it was included with all the stuff I got this) Any tips. it doesn't look like the screw is spinning but i haven't played my Nintendo DS Lite for 3 years.
    whittlegirls - 답글
    bonjour j’ai une petite question pour vous fais trés longtemps que j’ai pas utiliser mon nintendo ds lite et quand je le branche il allume 1 fois orange après il s’enteint même s’il est brancher ça veux tu dire qu’il faut que je change de batterie ? Merci
    Marie-Julie Richer - 답글
    Soit un changement de batterie, soit la carte-mère a peut-être un court-circuit :/
    Polaris -
  2. Nintendo DS Lite Battery Replacement: 2 단계, 이미지 1/1
    • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
    • Remove the battery from the DS Lite.
결론
다른 46명이 해당 안내서를 완성하였습니다.
Matthew Newsom
회원 가입일: 01/05/10
39,171 평판
안내서 67개 작성하였습니다
댓글 5개
Can you describe the type of screw and captive washer ?
Cornel Paraschiv - 답글
Thank you.
i just ordered a new battery as I already got a new power cord & it won’t charge at all.
Hoping new battery does the trick.
Thanks again.
T. Kellogg
Tamela Kellogg - 답글
Thanks but will a dsi battery work
Zach - 답글
My battery cover won’t come off.
Jake - 답글
Flip the console upside down and it will but don’t pull it will break hold it close to the console then slide it back
dead -
댓글 쓰기
조회 통계:
24 시간 전: 31
7일 전: 143
30일 전: 645
전체 시간: 49,317
