주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Prerequisite guide of Nintendo DS Lite lower LCD assembly.
부품
지정된 부품이 없습니다.
  1. Use your fingernail or the edge of a plastic opening tool to carefully flip up the lower LCD ribbon cable retaining flap. Make sure you are flipping up the retaining flap, not the socket itself.
    • Use your fingernail or the edge of a plastic opening tool to carefully flip up the lower LCD ribbon cable retaining flap.
    • Make sure you are flipping up the retaining flap, not the socket itself.
    • Pull the lower LCD assembly straight away to separate the lower LCD ribbon cable from its socket on the motherboard.
    • Remove the lower LCD assembly from the motherboard.
    • When reinstalling lower LCD, ensure it has insulation on the back to prevent a short circuit with the motherboard.
결론
Matthew Newsom
회원 가입일: 2010년 01월 05일
36,077 평판
안내서 67개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 510
