주요 콘텐츠로 건너뛰기
Nintendo DS Lite Shoulder Buttons Replacement
필요한 것
  1. Nintendo DS Lite Shoulder Buttons Replacement, Remove the battery cover: 1 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the screw securing the battery cover.
  2. Nintendo DS Lite Shoulder Buttons Replacement, Remove the lower case: 2 단계, 이미지 1개 중 1개
    • Use a spudger to pry out the battery.
    • Pry off the rubber feet.
    • Remove the seven screws securing the lower case:
    • Three tri-wing screws
    • One Phillips screw
    • Two gold Phillips screws
    • One black tri-wing screw
  3. Nintendo DS Lite Shoulder Buttons Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully pry the bottom cover off.
    • Remove the shoulder buttons by pulling out the metal pegs that secure them to DS.
    • The triggers are held in by tiny metal pegs and springs. Keep track of each piece.
  4. Nintendo DS Lite Shoulder Buttons Replacement: 4 단계, 이미지 3개 중 1개 Nintendo DS Lite Shoulder Buttons Replacement: 4 단계, 이미지 3개 중 2개 Nintendo DS Lite Shoulder Buttons Replacement: 4 단계, 이미지 3개 중 3개
    • You can now access the micro-button component and replace or repair anything as needed.
결론
To reassemble your device, follow the steps in reverse order after making your repair.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Francisco Varela
회원 가입일: 02/01/19
239 평판
안내서 1개를 작성함
5가이드 댓글
For anyone dealing with unresponsive shoulder buttons, I highly recommend watching this video guide;
https://www.youtube.com/watch?v=VnWdawXC...
Gabriel Branyiczky - 답글
たしかにそうですね!!!
kawagoe -
Thanks, this was very helpful. The ifixit guide doesn't include the needed details of how to clean the button contact. This fixed my issue.
Travis Kirk -
+1 on this! Didn't need to replace the button at all.
Isak -
とても、わかりやすくて、しっかり修理できました!
kawagoe - 답글
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 83
지난 30일: 323
전체 시간: 11,913
