소개
This guide has been updated by iFixit staff! Read the new, official guide here.
This guide will show you how to replace the wireless antenna in your DS Lite.
필요한 것
Place your device upside down and locate the battery compartment.
Find the Phillips head screw securing the battery cover in the bottom right hand corner of the device.
Remove the following seven screws that secure the lower case to the DS Lite:
Three silver tri-wing screws (5mm long)
One black tri-wing screw (4mm)
Two gold Phillips screws (4mm)
One silver Phillips screw (3mm)
Do not remove the silver PH screw (3mm) in the battery compartment yet. It holds the main PCB in place.
Flip the unit over so that it is facing right-side up.
Use a spudger to pry open the gap between the bottom case and the front panel. Work all the way around the case until the panel is free.
Avoid touching the L and R shoulder buttons, because they easily detach and are difficult to reassemble. Keep the bottom case flat against your workbench to help hold the shoulder buttons in place.
Locate the two screws that attach the logic board to the device.
Unscrew the two Phillips head screws.
Remove the two Phillips-head screws that hold the hinge in place.
Open the system up (just like if you were about to use it normally).
다른 한 분이 해당 안내서를 완성하였습니다.
