주요 콘텐츠로 건너뛰기
Nintendo DS Main Circuit Board Replacement
필요한 것
  1. Nintendo DS Main Circuit Board Replacement, Battery: 1 단계, 이미지 3개 중 1개 Nintendo DS Main Circuit Board Replacement, Battery: 1 단계, 이미지 3개 중 2개 Nintendo DS Main Circuit Board Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Remove the cartridge from the console.
    • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
    • Remove the battery door.
    • In the images, it shows that the fixer is using a flathead screwdriver. This flathead screwdriver will work just like the Phillips #00 Screwdriver.
  2. Nintendo DS Main Circuit Board Replacement: 2 단계, 이미지 1개 중 1개
    • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic opening tool or spudger isn't available, your fingernails may work.
  3. Nintendo DS Main Circuit Board Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the battery from the Nintendo DS.
  4. Nintendo DS Main Circuit Board Replacement, Back Panel: 4 단계, 이미지 1개 중 1개
    • Remove the seven 6.4mm Y00 screws located on the back.
    • If your DS has a lanyard attached to it, you can remove it to make the process of opening the top-left screw easier.
  5. Nintendo DS Main Circuit Board Replacement: 5 단계, 이미지 3개 중 1개 Nintendo DS Main Circuit Board Replacement: 5 단계, 이미지 3개 중 2개 Nintendo DS Main Circuit Board Replacement: 5 단계, 이미지 3개 중 3개
    • With your hands, pry the back panel off the main case.
    • Separate the back from the front, and set it aside.
  6. Nintendo DS Main Circuit Board Replacement, Motherboard replacement.: 6 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screwdriver, remove the four screws on the circuit board.
    • Be careful NOT to slip with the screwdriver, you can damage the circuit board!
  7. Nintendo DS Main Circuit Board Replacement: 7 단계, 이미지 3개 중 1개 Nintendo DS Main Circuit Board Replacement: 7 단계, 이미지 3개 중 2개 Nintendo DS Main Circuit Board Replacement: 7 단계, 이미지 3개 중 3개
    • Unlock the two large ribbon cables by moving the black clip up.
    • Carefully pull the ribbon cables down and out with your fingers.
    • Do not use pliers to pull the cables, as they can be damaged easily.
  8. Nintendo DS Main Circuit Board Replacement: 8 단계, 이미지 2개 중 1개 Nintendo DS Main Circuit Board Replacement: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Locate the two small ribbon cables, beneath the rightmost large ribbon cable.
    • Slide the locks for the small ribbon cables down to the side, and remove the cables.
    • It may be useful to use tweezers to remove the small ribbon cables.
    • Be careful not to damage the delicate ribbon cables.
  9. Nintendo DS Main Circuit Board Replacement: 9 단계, 이미지 2개 중 1개 Nintendo DS Main Circuit Board Replacement: 9 단계, 이미지 2개 중 2개
    • Locate the Wifi antenna pigtail connector.
    • Remove the antenna by grasping it at the head with tweezers. Using a slight rocking motion, pull up to dislodge the connector.
  10. Nintendo DS Main Circuit Board Replacement: 10 단계, 이미지 1개 중 1개
    • Feed the ribbon cables through the opening on the board.
    • Pull up and remove the circuit board, and set it aside.
결론
다른 23명이 해당 안내서를 완성하였습니다.
작성자
18다른 기여자 명과 함께
kingdesmond
회원 가입일: 10/27/09
2,210 평판
안내서 1개를 작성함
Cal Poly, Team 18-3, Maness Fall 2009 Cal Poly, Team 18-3, Maness Fall 2009 회원
CPSU-MANESS-F09S18G3
4 회원들
안내서 31개를 작성함
1가이드 댓글
This was really helpful. Thank you!
Jess Anderson - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 36
지난 30일: 192
전체 시간: 31,958
