주요 콘텐츠로 건너뛰기
Nintendo DSI Battery Replacement
필요한 것
  1. Nintendo DSI Battery Replacement, Setup and Parts: 1 단계, 이미지 1/1
    • To begin the battery replacement, have all your tools and parts nearby and ready to go.
    • Nintendo DSI
    • #00 2.0mm Phillips Head Screwdriver OR Precision Screwdriver Kit
    • Spudger or Prying Tool
    • Nintendo DSI Battery
  2. Nintendo DSI Battery Replacement, Accessing the battery compartment: 2 단계, 이미지 1/3 Nintendo DSI Battery Replacement, Accessing the battery compartment: 2 단계, 이미지 2/3 Nintendo DSI Battery Replacement, Accessing the battery compartment: 2 단계, 이미지 3/3
    • On the backside of the DSI, you'll notice a plastic panel with two screws off to the side. Unscrew both screws using a #00 Phillips head screwdriver or an appropriately sized screwdriver bit.
    • Unscrew both screws using a #00 Phillips head screwdriver or an appropriately sized screwdriver bit. The screws will stay with the panel during removal.
    • Lift the plastic panel up and away from the DSI. If the panel stays in place after unscrewing, hold the DSI upsidedown and gently tap the device. This should free the panel.
  3. Nintendo DSI Battery Replacement, Removing and Replacing the battery pack: 3 단계, 이미지 1/3 Nintendo DSI Battery Replacement, Removing and Replacing the battery pack: 3 단계, 이미지 2/3 Nintendo DSI Battery Replacement, Removing and Replacing the battery pack: 3 단계, 이미지 3/3
    • Once you've removed the plastic panel, you'll have full access to the battery pack.
    • Using the spudger/prytool or gently tapping the DSI, lift and remove the battery upwards and away from the device.
    • [IMPORTANT] when installing the replacement battery pack, make sure to line up the positive and negative terminals on the battery to those on the battery compartment on the DSI
  4. Nintendo DSI Battery Replacement, Finishing up: 4 단계, 이미지 1/1
    • Once you've reinstalled/replaced the battery pack. Reinstall the plastic panel, making sure to line up the plastic hinges on the side adjacent to the screws.
    • Drop the panel into place and retighten both of the screws.
결론
Congratulations! You just replaced your Nintendo DSi's battery!
다른 4명이 해당 안내서를 완성하였습니다.
Edrick Tong
회원 가입일: 01/26/22
217 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 23
30일 전: 94
전체 시간: 1,673
