1 단계 Battery
주의: 1-2 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Loosen the two screws on the battery panel. Then lift the panel up to remove it.
Two screws are hidden underneath two rubber feet highlighted in red.
Use the tip of a spudger to pry the rubber feet out of the lower case.
Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
7 단계 Disconnecting Nintendo DSi Battery Board
주의: 7-8 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Flip up the black latch and disconnect the D-Pad/Power Button ribbon cable.
The connector is two pieces -- a white "male" piece (connected to the wires), and a beige "female" part (soldered to the main board).
There is a small "notch" in the female part, to give you a place to insert a small flat-head screwdriver. Put the corner of your screwdriver in there, and twist it gently to push the white part up (away from the main board). Do not try to pull it to the right (towards the battery board).
9 단계 Motherboard
주의: 9-10 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Remove 4 Phillips screws from the board.
Lift the main board from the bottom end and flip it over to reveal the last connector.
11 단계 Disassembling Nintendo DSi Bottom case
주의: 11-13 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
A/B/X/Y button assembly
Select/Start button assembly
D-pad
Power button
14 단계 Top LCD Screen
주의: 14-23 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Using a spudger, or similar tool, pry out the 4 square screw covers.
On the bottom cover, use a screwdriver to remove the 3 Phillips screws holding the battery compartment.
Removing the 2 lower screws also removes the "L" trigger.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
Pictures are too dark to properly see where the structures mentioned in the text are, but worse than this, Steps 21 and 22 do not properly explain the “twist” method that you need to use with extreme caution! This is the Achille’s heel of dismantling the device and if you’re gonna make a mistake, let this not be the one…
