이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Loosen the two screws on the battery panel. Then lift the panel up to remove it.
L Button.
Top of the battery pack.
To remove the battery pack, place your fingernail or a spudger at the top of the battery near the L button. Gently lift the battery out.
Remove 4 Phillips screws from the board.
Lift the main board from the bottom end and flip it over to reveal the last connector.
Disconnect the ribbon cable by gently using a plastic opening tool to flip up the black connector latch. The cable should easily slide out from the connector.
The motherboard should now be free from the rest of the device.
A/B/X/Y button assembly
Select/Start button assembly
D-pad
Power button
Flip the case open, and push the lower screen assembly out of the frame.
Place a plastic opening tool between the front panel and top edge of the outer case. Slide the tool along the edge as needed to prop open the case.
With the screen facing you, slide the screen side down with your thumbs to separate the screen from the cover.
Remove the antenna from the bottom left of the device.
Remove the microphone from the top of the frame.
Start by pushing the sliding shaft in the hinge on the opposite side of the wires/ribbons.
On the reverse side of the casing, insert the spudger onto the surface of the sliding shaft just left of the LED light channels.
Push the sliding shaft completely through the hinge until it stops and the hinge is released.
The right side of bottom case should separate from the top case when you remove the sliding shaft.
Slide the top case to the right to separate the joint.
Weave the wires and ribbons through the wire hinge to completely separate the top and bottom casings.
Lift the top LCD out of the plastic frame. Carefully thread the ribbon cable out of the hinge to avoid damaging it.
To remove the speakers, place a flat object underneath and gently pry them off.
다른 한 분이 해당 안내서를 완성하였습니다.
