이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
빨간색으로 강조 표시된 두 개의 고무 받침 아래에 나사 두 개가 숨겨져 있습니다.
스퍼저 끝을 사용하여 고무 받침을 하단 케이스에서 들어 올리세요.
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Pull the stylus straight out its housing and remove it from the rear case.
Remove the five 3.9 mm Phillips screws securing the stylus holder to the rear case.
Lift and remove the left plastic protector from the DSi's rear case.
Grasp the stylus holder from the left side and lift upwards to remove it from the DSi.
Lift and dislodge the SD board from its housing within the rear case.
Peel the trigger buttons/SD board cable of its channel in the rear case.
Lift the steel battery tray out of the lower case and remove the trigger button/SD board assembly.
If your trigger button happens to fall apart during diassembly, the third picture shows its correct installed orientation. Be sure the spring is installed in the position shown, and that the two trigger button covers are unique to the side they are supposed to be installed in.
다른 27명이 해당 안내서를 완성하였습니다.
댓글 2개
I noticed some pencil marks on the inside of the lower shell that must have come from the factory. There is an m/ to the right of the foam pad, an ax to the right of that, and some kind of numeric marking that says 1T7 12 above the ribbon cable. I'm wondering if it has any significance.
Hi! I accidentally stripped the screws above the game slot , any ideas how to unscrew it without breaking my dsi?
