이 번역은 원본 안내서의 최신 업데이트를 반영하지 않을 수 있습니다. 번역 업데이트를 돕거나 아니면 원본 안내서 보기를 참조하세요.
소개
이 안내서는 DSi의 상단 LCD를 교체하는 방법을 설명합니다.
필요한 것
빨간색으로 강조 표시된 두 개의 고무 받침 아래에 나사 두 개가 숨겨져 있습니다.
스퍼저 끝을 사용하여 고무 받침을 하단 케이스에서 들어 올리세요.
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Pull the Wi-Fi board away from the motherboard by its edge closest to the headphone jack.
Pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
Use the tip of a spudger to pry the power board connector out of its socket on the motherboard.
Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following three ZIF sockets:
Lower touchscreen cable
Lower LCD cable
Power board cable
After flipping up the locking tabs on all three sockets, use your fingers or a pair of tweezers to gently pull the cables straight out of their sockets.
Use your fingernail or the edge of a plastic opening tool to carefully flip up the touchscreen ribbon cable retaining flap.
Use the tip of a spudger to pull the touchscreen ribbon cable straight out of its socket.
Use your fingernail or the edge of a plastic opening tool to carefully flip up the dual camera ribbon cable retaining flap.
Use the tip of a spudger to pull the dual camera ribbon cable straight out of its socket.
With the tip of a spudger, Pry the microphone antenna up off its socket on the motherboard.
Remove the following four Phillips screws securing the motherboard to the DSi framework.
Three longer screws.
One short screw.
Pull the microphone and Wi-Fi antenna cables out of the notch cut into the motherboard near the headphone jack.
Slightly lift the motherboard upwards to reveal the upper LCD ribbon cable above the ABXY buttons .
Use your fingernail or the edge of a plastic opening tool to carefully flip up the upper LCD ribbon cable retaining flap.
Remove the motherboard from the DSi.
Use the tip of a spudger to pry the metal backing of the lower LCD up from the DSi's framework.
Lift the lower LCD assembly out of the DSi.
Use a pushpin to remove the four plastic screw covers on the front bezel.
Remove the four Phillips screws securing the rear bezel to the front bezel.
Using two hands, gently slide the rear bezel upwards.
Slightly close the case of the DSi and lift the rear bezel straight up out of the DSi.
Continue de-routing the microphone and Wi-Fi antenna cables through the opening located on the bottom DSi's framework.
Remove the five Phillips screws securing the power board to the DSi's framework.
Lift and remove the power board from the DSi.
Push the metal hinge pin inward on the D-pad side of the front lower panel with the tip of a spudger.
The pin should move about 3 mm and stop. It is not necessary to try to completely remove the pin.
Slightly detach the lower and upper halves of the DSi.
De-route the upper LCD and dual camera ribbon cables through the slit near the ABXY side of the front lower panel.
Separate the lower and upper halves from each other.
Using your fingers, grasp the microphone cable and de-route it through the hinge.
The microphone will likely pop out of its housing, so it is probably easier to completely remove it at this point.
De-route the Wi-Fi cable through the hinge.
Tightly coil the display and dual camera ribbon cables enough to push them through the steel hinge tube.
Remove the steel hinge tube.
Carefully push both coiled ribbon cables through the tube molded into the front upper panel.
Pry the front-facing camera straight up out of its housing in the front bezel.
Lift the rear-facing camera out of its housing in the front bezel.
Remove the dual camera cable assembly from the DSi.
De-route the Wi-Fi antenna cable from its channel in the front bezel.
Lift the Wi-Fi antenna board straight up and remove it from the DSi.
Use the flat end of a spudger to pry the right speaker straight up and out of its housing in the front upper panel.
Lift the right speaker and set it on top of the upper LCD.
In the same manner as previously described, remove the left speaker.
De-route the left speaker cables from underneath the upper LCD.
Lay the left speaker on top of the upper LCD.
Cautiously wedge the flat end of spudger underneath the upper LCD.
Loosen the adhesive by running the spudger along the perimeter of the upper LCD.
Lift the upper LCD by its upper right corner and remove it from the front upper panel.
Desolder the speakers from the upper LCD by heating up the solder joints with a soldering iron and simultaneously using a pair of tweezers to pull the speaker wires away from the logic board.
기기를 재조립하려면 다음 지침을 역순으로 따르세요.
다른 30명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
20%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 12개
The tricky part is getting the upper screen and black ribbon through the hinge. I found that curling them and pushing them through a drinking straw that was cut short first and then pushing the straw through the hinge hole made it a whole lot easier.
So true. I just broke my second ribbon cable while replacing the case. While most repairs on the dsi are relatively easy, this ribbon cable makes any repairs that involve it a nightmare.
I curled the larger (new) cable the same way the smaller one was already curled. Just spend some time doing that until it was shaped that way and it was a lot easier to get both through the molded tube and ring.
Tplan -
While doing this I accident messed something up. When I power on the DSi, the bottom screen just flashes and the DS turns off. What did I do wrong?
