주요 콘텐츠로 건너뛰기
Nintendo DSi XL Right Shoulder Button Replacement
필요한 것
  1. Nintendo DSi XL Right Shoulder Button Replacement, Battery: 1 단계, 이미지 2개 중 1개 Nintendo DSi XL Right Shoulder Button Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Right Shoulder Button Replacement: 2 단계, 이미지 1개 중 1개
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Right Shoulder Button Replacement, Lower Case: 3 단계, 이미지 3개 중 1개 Nintendo DSi XL Right Shoulder Button Replacement, Lower Case: 3 단계, 이미지 3개 중 2개 Nintendo DSi XL Right Shoulder Button Replacement, Lower Case: 3 단계, 이미지 3개 중 3개
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Right Shoulder Button Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Right Shoulder Button Replacement: 5 단계, 이미지 3개 중 1개 Nintendo DSi XL Right Shoulder Button Replacement: 5 단계, 이미지 3개 중 2개 Nintendo DSi XL Right Shoulder Button Replacement: 5 단계, 이미지 3개 중 3개
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Right Shoulder Button Replacement: 6 단계, 이미지 2개 중 1개 Nintendo DSi XL Right Shoulder Button Replacement: 6 단계, 이미지 2개 중 2개
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Right Shoulder Button Replacement: 7 단계, 이미지 2개 중 1개 Nintendo DSi XL Right Shoulder Button Replacement: 7 단계, 이미지 2개 중 2개
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Right Shoulder Button Replacement, Right Shoulder Button: 8 단계, 이미지 3개 중 1개 Nintendo DSi XL Right Shoulder Button Replacement, Right Shoulder Button: 8 단계, 이미지 3개 중 2개 Nintendo DSi XL Right Shoulder Button Replacement, Right Shoulder Button: 8 단계, 이미지 3개 중 3개
    • Remove the two gold 4.0 mm Phillips screws securing the right shoulder button assembly to the back case.
    • Lift the right shoulder button assembly from the back case.
    • The components of the right shoulder button assembly:
    • Right shoulder button
    • Shoulder button spring
    • Retaining pin
    • Right shoulder button holding panel
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Brett Hartt
회원 가입일: 04/12/10
131,266 평판
안내서 143개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 44
지난 30일: 169
전체 시간: 11,573
