이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Give your DSi a memory boost by repairing your SD board.
필요한 것
Remove the two Phillips screws securing the battery cover to the back of the handheld console.
Lift the battery cover off the back of the DSi XL.
Remove the four rubber screw covers on the lower case by prying them up with a push pin.
Remove the two gold 4.0 mm Phillips screws securing the right shoulder button assembly to the back case.
Lift the right shoulder button assembly from the back case.
The components of the right shoulder button assembly:
Right shoulder button
Shoulder button spring
Retaining pin
Right shoulder button holding panel
다른 한 분이 해당 안내서를 완성하였습니다.
