주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Replace your DSi XL's speakers so you can hear Mario yell "Mamma mia" as clear as ever.
  1. Remove the two Phillips screws securing the battery cover to the back of the handheld console. Lift the battery cover off the back of the DSi XL.
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Lift the battery from the DSi XL.
    • Lift the battery from the DSi XL.
  3. Use a push pin to remove the four plastic screw covers on the front bezel. Use a push pin to remove the four plastic screw covers on the front bezel. Use a push pin to remove the four plastic screw covers on the front bezel.
    • Use a push pin to remove the four plastic screw covers on the front bezel.
  4. Remove four Phillips screws securing the front bezel to the rear bezel.
    • Remove four Phillips screws securing the front bezel to the rear bezel.
  5. Using two hands, gently slide the rear bezel upwards. The rear bezel will move only about 2 mm.
    • Using two hands, gently slide the rear bezel upwards.
    • The rear bezel will move only about 2 mm.
  6. Insert a spudger into the gap between the front and rear bezel Rotate the spudger away from the DSi XL, prying the two bezels apart.
    • Insert a spudger into the gap between the front and rear bezel
    • Rotate the spudger away from the DSi XL, prying the two bezels apart.
  7. In the same manner as described above, continue prying along the top edge of the front and rear bezels.
    • In the same manner as described above, continue prying along the top edge of the front and rear bezels.
  8. Separate the rear bezel from the front bezel.
    • Separate the rear bezel from the front bezel.
    • Do not attempt to completely remove the rear bezel yet. It is still attached to the front bezel by the rear-facing camera.
  9. Use the flat end of a spudger to pry the rear camera off the rear bezel.
    • Use the flat end of a spudger to pry the rear camera off the rear bezel.
    • Remove the rear bezel.
  10. Use a spudger to lift the antenna from the front bezel to make room for lifting the speaker cables up.
    • Use a spudger to lift the antenna from the front bezel to make room for lifting the speaker cables up.
  11. Use a spudger to lift the right speaker from its housing in the front bezel.
    • Use a spudger to lift the right speaker from its housing in the front bezel.
  12. Use a spudger to lift the left speaker from its housing in the front bezel.
    • Use a spudger to lift the left speaker from its housing in the front bezel.
  13. De-route the left speaker cable along the top edge of the upper LCD. De-route the left speaker cable along the top edge of the upper LCD.
    • De-route the left speaker cable along the top edge of the upper LCD.
  14. Open the display slightly, and lift the LCD out of the front bezel.
    • Open the display slightly, and lift the LCD out of the front bezel.
    • Lay the LCD down next to the DSi XL.
    • Don't attempt to remove the LCD, it is still attached to the front bezel via the display data ribbon cable.
  15. Desolder the two solder joints to separate the speakers from the LCD.
    • Desolder the two solder joints to separate the speakers from the LCD.
    • Right Speaker
    • Left Speaker
    • For both speakers, the red wire (positive lead) is soldered to the left contact. The black wire (negative lead) is soldered to the right contact point.
    • For detailed instructions on how to solder this type of connection, see our guide for repairing soldered connections.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Matthew Newsom
회원 가입일: 2010년 01월 05일
36,020 평판
안내서 67개 작성하였습니다
Thank you for this video but I need some more help cause I dont know if my problem are the speakers or the earphones jack how can I solve this just one clue i need thanks again
Josh - 답글
In my case, it turned out there was nothing wrong with my speaker… one of the wires that feeds around the screen was bad.
Dave Horlick - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 18
전체 시간: 5,855
