소개
Replace your DSi XL's speakers so you can hear Mario yell "Mamma mia" as clear as ever.
필요한 것
Remove the two Phillips screws securing the battery cover to the back of the handheld console.
Lift the battery cover off the back of the DSi XL.
Use a spudger to lift the antenna from the front bezel to make room for lifting the speaker cables up.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 3개
In my case, it turned out there was nothing wrong with my speaker… one of the wires that feeds around the screen was bad.
is there anyway of adding two more speaker?
rust/white powder built up on a screw and can’t unscrew it
Eco - 답글
