이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the two Phillips screws securing the battery cover to the back of the handheld console.
Lift the battery cover off the back of the DSi XL.
Remove the four rubber screw covers on the lower case by prying them up with a push pin.
Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
Four silver 5.3 mm screws
Two black 5.3 mm screws
One black 2.5 mm screw
Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
Lift the lower case from the front edge.
Rotate the lower case away from the DSi.
Using a spudger, pry the SD card/right shoulder button connector off its socket.
Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
On the inside of the battery compartment, use the tip of a spudger to detach the metal latch securing the volume control switch in place.
Using the flat end of a spudger, remove the adhesive securing the volume control switch ribbon cable to the back of the battery compartment.
Using the flat of a spudger, pry the volume control switch straight up out of the lower case.
Remove the volume control switch from the DSi XL.
Using the flat end of a spudger, remove the volume control buttons from the metal backing bracket.
Volume control switch remains.
이 단계에 사용된 도구:Tweezers$4.99-
While pushing the volume buttons through their holes in the lower case, remove the buttons and their silicone pads with a pair of tweezers.
Remove the buttons from the silicone pad.
다른 한 분이 해당 안내서를 완성하였습니다.
