주요 콘텐츠로 건너뛰기
Nintendo DSi XL Wi-Fi Board Replacement
필요한 것
  1. Nintendo DSi XL Wi-Fi Board Replacement, Battery: 1 단계, 이미지 2개 중 1개 Nintendo DSi XL Wi-Fi Board Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Wi-Fi Board Replacement: 2 단계, 이미지 1개 중 1개
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Wi-Fi Board Replacement, Lower Case: 3 단계, 이미지 3개 중 1개 Nintendo DSi XL Wi-Fi Board Replacement, Lower Case: 3 단계, 이미지 3개 중 2개 Nintendo DSi XL Wi-Fi Board Replacement, Lower Case: 3 단계, 이미지 3개 중 3개
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Wi-Fi Board Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Wi-Fi Board Replacement: 5 단계, 이미지 3개 중 1개 Nintendo DSi XL Wi-Fi Board Replacement: 5 단계, 이미지 3개 중 2개 Nintendo DSi XL Wi-Fi Board Replacement: 5 단계, 이미지 3개 중 3개
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Wi-Fi Board Replacement: 6 단계, 이미지 2개 중 1개 Nintendo DSi XL Wi-Fi Board Replacement: 6 단계, 이미지 2개 중 2개
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Wi-Fi Board Replacement: 7 단계, 이미지 2개 중 1개 Nintendo DSi XL Wi-Fi Board Replacement: 7 단계, 이미지 2개 중 2개
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Wi-Fi Board Replacement, Wi-Fi Board: 8 단계, 이미지 2개 중 1개 Nintendo DSi XL Wi-Fi Board Replacement, Wi-Fi Board: 8 단계, 이미지 2개 중 2개
    • Lift the Wi-Fi board up off its socket on the motherboard.
    • Do not attempt to completely remove the Wi-Fi board yet. It is attached to the motherboard by an antenna cable.
  9. Nintendo DSi XL Wi-Fi Board Replacement: 9 단계, 이미지 1개 중 1개
    • Use a spudger to pry the Wi-Fi cable off its socket on the underside of the Wi-Fi board.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Brett Hartt
회원 가입일: 04/12/10
129,851 평판
안내서 143개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,474개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 37
지난 30일: 154
전체 시간: 14,184
