주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo Entertainment System 72-PIN Connector Replacement
필요한 것
  1. Nintendo Entertainment System 72-PIN Connector Replacement, Game Cartridge Tray: 1 단계, 이미지 2개 중 1개 Nintendo Entertainment System 72-PIN Connector Replacement, Game Cartridge Tray: 1 단계, 이미지 2개 중 2개
    • Remove the six 13.25mm Phillips screws on the bottom of the game console with a #2.5 flathead screwdriver.
    • The screws are recessed about 40 mm.
    • Flip the game console right side up and take off the top by pulling it up and away from the rest of the device with your hands.
  2. Nintendo Entertainment System 72-PIN Connector Replacement: 2 단계, 이미지 2개 중 1개 Nintendo Entertainment System 72-PIN Connector Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the seven 13.25mm Phillips screws from the metal cover with a Phillips head #2 screwdriver.
    • Remove the metal cover by pulling it up and away from the rest of the console with your hands.
  3. Nintendo Entertainment System 72-PIN Connector Replacement: 3 단계, 이미지 3개 중 1개 Nintendo Entertainment System 72-PIN Connector Replacement: 3 단계, 이미지 3개 중 2개 Nintendo Entertainment System 72-PIN Connector Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the two silver 17.45mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
    • Remove the two bronze 13.25mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
    • Slide the cartridge tray toward you, away from the 72-PIN connector, and off the motherboard assembly.
  4. Nintendo Entertainment System 72-PIN Connector Replacement: 4 단계, 이미지 2개 중 1개 Nintendo Entertainment System 72-PIN Connector Replacement: 4 단계, 이미지 2개 중 2개
    • Note: Underneath the cartridge tray is a black trapezoid-shaped tab/lip (see marker). When properly assembled this tab/lip goes below the motherboard and shielding as seen here.
    • During reassembly, make sure you orient this tab underneath the motherboard in addition to orienting the tray on top. Failure to do so will bow the cartridge tray and place stress on the component, causing the cartridge spring mechanism to bind.
  5. Nintendo Entertainment System 72-PIN Connector Replacement, Motherboard: 5 단계, 이미지 3개 중 1개 Nintendo Entertainment System 72-PIN Connector Replacement, Motherboard: 5 단계, 이미지 3개 중 2개 Nintendo Entertainment System 72-PIN Connector Replacement, Motherboard: 5 단계, 이미지 3개 중 3개
    • Remove the three 13.25mm Phillips screws that secure the motherboard to the lower case with a Phillips head #2 screwdriver.
    • Pull the motherboard assembly straight up and out of the plastic case with your hands.
    • Turn the motherboard assembly over so the metal cover is facing you.
  6. Nintendo Entertainment System 72-PIN Connector Replacement: 6 단계, 이미지 1개 중 1개
    • Disconnect the wire harnesses from the motherboard assembly:
    • Controller 1 (left)
    • Controller 2 (right)
    • Power
    • To prevent mixing the wires up during reassembly, it can be helpful to label the wires with a piece of tape.
  7. Nintendo Entertainment System 72-PIN Connector Replacement: 7 단계, 이미지 3개 중 1개 Nintendo Entertainment System 72-PIN Connector Replacement: 7 단계, 이미지 3개 중 2개 Nintendo Entertainment System 72-PIN Connector Replacement: 7 단계, 이미지 3개 중 3개
    • Lift off the EMI shield (metal cover) from the motherboard assembly.
    • Turn over the motherboard assembly so the 72-PIN connector is on the top of the motherboard assembly.
결론
다른 88명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
nicholasweiser
회원 가입일: 09/22/10
2,757 평판
안내서 6개를 작성함
Cal Poly, Team 14-40, Forte Fall 2010 Cal Poly, Team 14-40, Forte Fall 2010 회원
CPSU-FORTE-F10S14G40
4 회원들
안내서 28개를 작성함
13가이드 댓글
Because it wasn't terribly clear, the pin connector pulls off from the motherboard. Just pull straight away from the board to clear the connector. It takes some force to get it off.
Dylan Peterson - 답글 공유
And, no wires need to be disconnected either.
Very easy repair.
justinlamoureux - 답글 공유
"How to replace your 72 pin connector"
Leaves out the steps that show how to remove the 72 pin connector.
Priceless
punch0073735963 - 답글 공유
Um are we missing the last steps on how to actually remove the 72pin connector???
Connor Gray - 답글 공유
I replaced mine, and I'm still getting a solid white screen. Any ideas what else it might be?
Brandon Dixon - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 20
지난 7일: 153
지난 30일: 766
전체 시간: 162,365
