소개
NES cover yellowed, cracked, fell out? This guide will help you get the look of the NES back in order.
Unfortunately, the cover does not come with the imprint "European Edition", but everything works as usual.
필요한 것
Remove the six 13.50mm PH2 screws from the base plate.
Now take off the upper part of the housing.
Take the top housing and turn it over.
Remove the four 7,80mm flathead screws.
Remove both metal clips.
Pull the front black cap off upwards.
Now lift the flap out at an angle.
The new flap can now be inserted.
Work the steps in reverse order to reassemble your device.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
