주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo Entertainment System Game Cartridge Tray Replacement
필요한 것
    1. Nintendo Entertainment System Game Cartridge Tray Replacement, Game Cartridge Tray: 1 단계, 이미지 2개 중 1개 Nintendo Entertainment System Game Cartridge Tray Replacement, Game Cartridge Tray: 1 단계, 이미지 2개 중 2개
      • Remove the six 13.25mm Phillips screws on the bottom of the game console with a #2.5 flathead screwdriver.
      • The screws are recessed about 40 mm.
      • Flip the game console right side up and take off the top by pulling it up and away from the rest of the device with your hands.
      댓글 쓰기
    2. Nintendo Entertainment System Game Cartridge Tray Replacement: 2 단계, 이미지 2개 중 1개 Nintendo Entertainment System Game Cartridge Tray Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the seven 13.25mm Phillips screws from the metal cover with a Phillips head #2 screwdriver.
      • Remove the metal cover by pulling it up and away from the rest of the console with your hands.
      댓글 쓰기
    3. Nintendo Entertainment System Game Cartridge Tray Replacement: 3 단계, 이미지 3개 중 1개 Nintendo Entertainment System Game Cartridge Tray Replacement: 3 단계, 이미지 3개 중 2개 Nintendo Entertainment System Game Cartridge Tray Replacement: 3 단계, 이미지 3개 중 3개
      • Remove the two silver 17.45mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
      • Remove the two bronze 13.25mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
      • Slide the cartridge tray toward you, away from the 72-PIN connector, and off the motherboard assembly.
      댓글 쓰기
    4. Nintendo Entertainment System Game Cartridge Tray Replacement: 4 단계, 이미지 2개 중 1개 Nintendo Entertainment System Game Cartridge Tray Replacement: 4 단계, 이미지 2개 중 2개
      • Note: Underneath the cartridge tray is a black trapezoid-shaped tab/lip (see marker). When properly assembled this tab/lip goes below the motherboard and shielding as seen here.
      • During reassembly, make sure you orient this tab underneath the motherboard in addition to orienting the tray on top. Failure to do so will bow the cartridge tray and place stress on the component, causing the cartridge spring mechanism to bind.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 11명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
nicholasweiser
회원 가입일: 09/22/10
2,781 평판
안내서 6개를 작성함
Cal Poly, Team 14-40, Forte Fall 2010 Cal Poly, Team 14-40, Forte Fall 2010 회원
CPSU-FORTE-F10S14G40
4 회원들
안내서 72개를 작성함
1가이드 댓글
I’m looking for a part that latches the tray into place it’s light blue in colour with a groove in it
Tony - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 42
지난 30일: 133
전체 시간: 18,249
