소개
The battery is a rectangular unit with electrical information printed on one side. It is located on the back of the Game Boy Advance SP.
도구
부품
Use a standard Phillips #00 screwdriver to loosen the 4mm screw that keeps the battery cover attached to the device.
For reassembly, follow the instructions in reverse order.
다른 20명이 해당 안내서를 완성하였습니다.
댓글 2개
This task is not very easy, its easy.
Very easy: Does not require opening device.
Easy: Requires minimal disassembly and requires a few tools like a Philips or flat-head screwdriver.
This however requires opening device.
Santi12008 - 답글
