이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
If the battery within your Game Boy Advanced SP doesn’t last long, or the console does not turn on at all, you might need to replace it. The following process applies to both the AGS - 100 and the AGS - 101 models of the console. If the battery has never been replaced, be careful when disassembling the unit, because the battery may have swelled over time which can be a potential hazard. Additionally, make sure that the console is not connected to an power source while performing the battery replacement process.
For a replacement battery, see the link below:
필요한 것
Use a standard Phillips #00 screwdriver to loosen the 4mm screw that keeps the battery cover attached to the device.
For reassembly, follow the instructions in reverse order.
다른 30명이 해당 안내서를 완성하였습니다.
댓글 2개
This task is not very easy, its easy.
Very easy: Does not require opening device.
Easy: Requires minimal disassembly and requires a few tools like a Philips or flat-head screwdriver.
This however requires opening device.
Santi12008 - 답글
