주요 콘텐츠로 건너뛰기
Nintendo Game Boy Advance SP Speaker Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Nintendo Game Boy Advance SP Speaker Replacement, Removing the back plate: 1 단계, 이미지 3개 중 1개 Nintendo Game Boy Advance SP Speaker Replacement, Removing the back plate: 1 단계, 이미지 3개 중 2개 Nintendo Game Boy Advance SP Speaker Replacement, Removing the back plate: 1 단계, 이미지 3개 중 3개
    • Start by removing the battery cover and take out the battery.
    • Remove the 6 tri point screws on the back plating.
    • The back plate should lift right off.
    • Also remove the 3 phillip screws on the mother board.
  2. Nintendo Game Boy Advance SP Speaker Replacement, Pull up the mother board: 2 단계, 이미지 1개 중 1개
    • Pull up the mother board from the bottom, opposite the ribbon cable. Try not to put any stress on the ribbon cable.
  3. Nintendo Game Boy Advance SP Speaker Replacement, Replacing the speaker and re assembly: 3 단계, 이미지 1개 중 1개
    • The speaker makes contact to the mother board by two pads, no soldering required. Just place the new speaker in it's slot along with the rest of the buttons.
    • To re assemble put back down the mother board to it's original position and follow the steps in reverse. I would recommend doing a dry test by just holding the console together and testing it out before you screw anything back in.
    • A few things for re assembly , make sure the power switch remains in the back casing as it can easily fall out, and make sure it is set to off. Do not lose the square nut on the back casing as it is not replaceable.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Chase
회원 가입일: 01/19/22
163 평판
안내서 1개를 작성함
1가이드 댓글
Didn't need to replace it but needed to re-seat it and bend its pins up enough to make consistent contact since audio was cutting out here and there. This was super helpful!
bilowik - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 1,271
