주요 콘텐츠로 건너뛰기
Nintendo GameCube Controller C Stick Replacement
필요한 것
  1. Nintendo GameCube Controller C Stick Replacement, Back Panel: 1 단계, 이미지 1/1
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
  2. Nintendo GameCube Controller C Stick Replacement: 2 단계, 이미지 1/1
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
    For some reason, it was simpler to take the top half off, although it could be because it is most probably refurbished before
    Rukir Gaming - 답글
  3. Nintendo GameCube Controller C Stick Replacement, Z Button: 3 단계, 이미지 1/2 Nintendo GameCube Controller C Stick Replacement, Z Button: 3 단계, 이미지 2/2
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
    So how do you put it back in like the replacement because I have a controller I'm working a junker my Friend gave me and I'm trying to fix it the z button doesn't work here it's a pelican wireless controller it's actually not to bad bulky but not bad
    Justin Sebastian - 답글
  4. Nintendo GameCube Controller C Stick Replacement, Circuit Board: 4 단계, 이미지 1/1
    • Carefully unhook the cable that is looped around the peg.
    Um can soneone explain the peg and cable part? I dont understand it...
    Tyler Goamez - 답글
    I would say that the cable is somehow "hooked" to the case and you have to get the cable away from the case so that you can pull out the board
    My1 -
  5. Nintendo GameCube Controller C Stick Replacement: 5 단계, 이미지 1/1
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
  6. Nintendo GameCube Controller C Stick Replacement, C Stick: 6 단계, 이미지 1/3 Nintendo GameCube Controller C Stick Replacement, C Stick: 6 단계, 이미지 2/3 Nintendo GameCube Controller C Stick Replacement, C Stick: 6 단계, 이미지 3/3
    • Use your fingers to grab the two sides of the connector and gently wiggle out.
    • Be sure not to pull on the cables. This may pull the cables out and damage your device even more.
    what kind of c stick is that? And Where can I get one?
    Axel Torres - 답글
  7. Nintendo GameCube Controller C Stick Replacement: 7 단계, 이미지 1/2 Nintendo GameCube Controller C Stick Replacement: 7 단계, 이미지 2/2
    • Grab the yellow cover by the base and pull it off.
    • During reassembly, make sure the slots inside the joy stick line up so they can fit back together.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Sean Michel
회원 가입일: 01/14/13
2,496 평판
안내서 8개 작성하였습니다
Cal Poly, Team 19-44, Regan Winter 2013 Cal Poly, Team 19-44, Regan Winter 2013 회원
CPSU-REGAN-W13S19G44
4 회원들
안내서 26개 작성하였습니다
댓글 2개
This doesnt help by c stick is broken and i need help. Up and down work just fine on it, but it doesnt rgister left and right. Anybody have any help?
Shane Roy - 답글
I did a mod on it and it worked fine until then but its really weird that left and right arent working but up and down are i couldve accidentally got hot glue in there... Any way to buy an entirely new c stick unit?
Shane Roy -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 20
30일 전: 75
전체 시간: 21,180
