주요 콘텐츠로 건너뛰기
Nintendo GameCube Controller Circuit Board Replacement
필요한 것
  1. Nintendo GameCube Controller Circuit Board Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
  2. Nintendo GameCube Controller Circuit Board Replacement: 2 단계, 이미지 1개 중 1개
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
  3. Nintendo GameCube Controller Circuit Board Replacement, Z Button: 3 단계, 이미지 2개 중 1개 Nintendo GameCube Controller Circuit Board Replacement, Z Button: 3 단계, 이미지 2개 중 2개
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
  4. Nintendo GameCube Controller Circuit Board Replacement, Circuit Board: 4 단계, 이미지 1개 중 1개
    • Carefully unhook the cable that is looped around the peg.
  5. Nintendo GameCube Controller Circuit Board Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Sean Michel
회원 가입일: 01/14/13
2,600 평판
안내서 8개를 작성함
Cal Poly, Team 19-44, Regan Winter 2013 Cal Poly, Team 19-44, Regan Winter 2013 회원
CPSU-REGAN-W13S19G44
4 회원들
안내서 32개를 작성함
2가이드 댓글
Yeah this isn't very in-depth, I was hoping for a little more. I need to desolder and rewire the buttons to use for another project and I was hoping this might be a nice guide to help me do that... it's not.
Joshua Arcari - 답글
You left out the fun facts about every part and components so we know what the are and what they do. Well for me that would have been ideal as I'm fixing 2 controls that don't do anything and I already have to fix a game cube as I got 2 and one works and one don't lol
Don'tcare69 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 29
지난 30일: 99
전체 시간: 19,775
