소개
The Left and Right triggers are located on the back side of the controller near the cord. The triggers are spring loaded.
부품
부품은 필요하지 않습니다.
Place the controller (buttons down) on a solid surface.
Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
In order to remove the other trigger, simply repeat Steps 6 through Step 9 on the right side.
다른 5명이 해당 안내서를 완성하였습니다.
