소개
The Left and Right triggers are located on the back side of the controller near the cord. The triggers are spring loaded.
필요한 것
Place the controller (buttons down) on a solid surface.
Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
In order to remove the other trigger, simply repeat Steps 6 through Step 9 on the right side.
다른 10명이 해당 안내서를 완성하였습니다.
2 댓글
Hallo ich habe da mal eine Frage. Ist es möglich die Empfindlichkeit der Trigger zu beeinflussen ? Leider reagieren sie erst sehr spät da mann den Knopf sehr weit hereindrücken muss.
danke schon mal
Otti
Ottitrotti - 답글
