주요 콘텐츠로 건너뛰기
Nintendo GameCube Controller Z Button Replacement
필요한 것
  1. Nintendo GameCube Controller Z Button Replacement, Back Panel: 1 단계, 이미지 1/1
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
  2. Nintendo GameCube Controller Z Button Replacement: 2 단계, 이미지 1/1
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
    For some reason, it was simpler to take the top half off, although it could be because it is most probably refurbished before
    Rukir Gaming - 답글
  3. Nintendo GameCube Controller Z Button Replacement, Z Button: 3 단계, 이미지 1/2 Nintendo GameCube Controller Z Button Replacement, Z Button: 3 단계, 이미지 2/2
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
    So how do you put it back in like the replacement because I have a controller I'm working a junker my Friend gave me and I'm trying to fix it the z button doesn't work here it's a pelican wireless controller it's actually not to bad bulky but not bad
    Justin Sebastian - 답글
결론
다른 7명이 해당 안내서를 완성하였습니다.
Sean Michel
회원 가입일: 01/14/13
2,496 평판
안내서 8개 작성하였습니다
Cal Poly, Team 19-44, Regan Winter 2013 Cal Poly, Team 19-44, Regan Winter 2013 회원
CPSU-REGAN-W13S19G44
4 회원들
안내서 26개 작성하였습니다
댓글 6개
My z button presses down and makes the click, but it does not actually send any input to the controller. How do you fix this?
Augustine Park - 답글
So how do you put it back in like the replacement because I have a controller I'm working with a junker my Friend gave me and I'm trying to fix it the z button doesn't work here is a pic
My bad no pic it's a pelican wireless controller
Justin Sebastian -
How do you change the spring? I have replacement z buttons just no spring for them…
Gaf Epar - 답글
Does that silver bar on the bottom of the Z button supposed to be there? My Z button does not have that, is it important for the button to have that?
Kevin Alaniz - 답글
Does anyone know where to buy the actual button for the Z button? I can’t seem to find one where the pins are further apart up top and closer together towards the bottom of the button. I only see the opposite.
Haig Karakashian - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 20
30일 전: 98
전체 시간: 18,828
