이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Removing these panels allows further access to the GameCube's components.
필요한 것
Turn over the Gamecube so that the bottom side is facing up.
Use the 4.5 mm Gamebit screwdriver to remove all four screws.
Gently press down on the clips located on either side of the the back panel, as shown, and carefully remove it from the main part of the device.
다른 4명이 해당 안내서를 완성하였습니다.
