주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Nintendo GameCube 수리는 저희 서비스 설명서를 사용하십시오.
  1. Nintendo GameCube Teardown, Nintendo GameCube Teardown: 1 단계, 이미지 1/3 Nintendo GameCube Teardown, Nintendo GameCube Teardown: 1 단계, 이미지 2/3 Nintendo GameCube Teardown, Nintendo GameCube Teardown: 1 단계, 이미지 3/3
    • Flip the unit upside down and remove the screws sitting in the four deep holes in the corners using a 4.5mm gamebit driver. Don't remove the enclosure yet!
    • Turn the device right side up again, and now lift the top case off. It'll come up easily.
  2. Nintendo GameCube Teardown: 2 단계, 이미지 1/3 Nintendo GameCube Teardown: 2 단계, 이미지 2/3 Nintendo GameCube Teardown: 2 단계, 이미지 3/3
    • Unsnap the controller port cover and the rearmost I/O-cover by unsnapping the two snaps on the sides of each cover. Don't remove the controller panel yet.
    • Then remove the heatsinks of the memory card slots (necessary step).
  3. Nintendo GameCube Teardown: 3 단계, 이미지 1/3 Nintendo GameCube Teardown: 3 단계, 이미지 2/3 Nintendo GameCube Teardown: 3 단계, 이미지 3/3
    • Now start removing the 'normal' Phillips #2 screws.
    • Start by removing the fan assembly.
    • then unscrew the 12 visible screws on the edging of the now not so cube-shaped GameCube.
  4. Nintendo GameCube Teardown: 4 단계, 이미지 1/1
    • Now you can lift the drive assembly up. You maybe have to loosen it a bit with a screwdriver or a heavy duty spudger.
    • The mainboard is now visible.
  5. Nintendo GameCube Teardown: 5 단계, 이미지 1/2 Nintendo GameCube Teardown: 5 단계, 이미지 2/2
    • Now remove the heatsink. Unscrew the six screws holding it.
    • Now use anything flat and durable to carefully lift up the heatsink by putting it under the aluminium and using it gently as a lever.
  6. Nintendo GameCube Teardown: 6 단계, 이미지 1/2 Nintendo GameCube Teardown: 6 단계, 이미지 2/2
    • If there are thermal pads remaining on the processors and/or ram chips, remove them with a plastic spudger.
    • Now disconnect the controller port panel connector by lifting and jiggling it carefully. It should come off easily.
  7. Nintendo GameCube Teardown: 7 단계, 이미지 1/2 Nintendo GameCube Teardown: 7 단계, 이미지 2/2
    • 24 MB MoSys 1T-SRAM
    • ATI 'Flipper' GPU, 162 MHz with 3 MB 1T-SRAM embedded within the die
    • IBM 'Gekko' CPU, 486 MHz (PowerPC 750CXe-based core)
    • Connectors (2nd pic):
    • 'Hi Speed Port'
    • 'Serial Port 1'
    • 'Serial Port 2'
  8. Nintendo GameCube Teardown: 8 단계, 이미지 1/3 Nintendo GameCube Teardown: 8 단계, 이미지 2/3 Nintendo GameCube Teardown: 8 단계, 이미지 3/3
    • If you lift the mainboard up, you'll see a metal plate, probably for EMI-protection. Remove the two screws holding it and you have access to the internal power supply.
Thomas J
회원 가입일: 01/24/10
409 평판
안내서 1개 작성함
댓글 13개
Great teardown Thomas!
Miroslav Djuric - 답글
Miroslav Djuric로 부터 인용:
Thanks!
Thomas J - 답글
WOW! Great work, Nintendo stuff is hard to open!
Mc128k - 답글
Mc128k로 부터 인용:
Thank you! Everything beyond Triwing requires creativity.
Thomas J - 답글
Will I need to reapply the thermal paste?
http://i.imgur.com/Q6antAn.jpg
Calvin Hall - 답글
댓글 쓰기
조회 통계:
24 시간 전: 34
7일 전: 231
30일 전: 1,202
전체 시간: 135,836
