주요 콘텐츠로 건너뛰기
Nintendo GameCube Top Case Replacement
필요한 것
  1. Nintendo GameCube Top Case Replacement, Top Case: 1 단계, 이미지 1/3 Nintendo GameCube Top Case Replacement, Top Case: 1 단계, 이미지 2/3 Nintendo GameCube Top Case Replacement, Top Case: 1 단계, 이미지 3/3
    • Turn over the Gamecube so that the bottom side is facing up.
    • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
  2. Nintendo GameCube Top Case Replacement: 2 단계, 이미지 1/3 Nintendo GameCube Top Case Replacement: 2 단계, 이미지 2/3 Nintendo GameCube Top Case Replacement: 2 단계, 이미지 3/3
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
    • Move the GameCube so that the inside is facing upwards.
    This can also be done whilst being in the normal upright position after all 4 of the 4.5mm Gamebit screws have been removed. Pull the top of the shell directly upwards and it should slide off easily.
    Less chance of snagging any wires or parts.
    Christopher Cox - 답글
결론
다른 13명이 해당 안내서를 완성하였습니다.
dcarlin
회원 가입일: 11/05/09
301 평판
안내서 4개 작성하였습니다
Cal Poly, Team 6-2, Maness Fall 2009 Cal Poly, Team 6-2, Maness Fall 2009 회원
CPSU-MANESS-F09S6G2
4 회원들
안내서 45개 작성하였습니다
댓글 한 개
Can you do a more in-depth version of the top cover? I had to clean each piece and need help figuring out where all the pieces go. Thanks
JJ Jackson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 31
30일 전: 162
전체 시간: 24,455
