주요 콘텐츠로 건너뛰기
Nintendo Gameboy Pocket Shell-Side Battery Terminal Corrosion Removal
필요한 것
  1. Nintendo Gameboy Pocket Shell-Side Battery Terminal Corrosion Removal, Nintendo Gameboy Pocket Shell-Side Battery Terminal Corrosion Removal: 1 단계, 이미지 1/1
    • Remove the battery cover and batteries.
  2. Nintendo Gameboy Pocket Shell-Side Battery Terminal Corrosion Removal: 2 단계, 이미지 1/1
    • Remove the six 8mm screws using a Y1 Tri-point screwdriver.
    • Place your screws in a small container to keep them safe.
  3. Nintendo Gameboy Pocket Shell-Side Battery Terminal Corrosion Removal: 3 단계, 이미지 1/1
    • Separate the front and back side of the Gameboy by gently pulling them apart.
  4. Nintendo Gameboy Pocket Shell-Side Battery Terminal Corrosion Removal: 4 단계, 이미지 1/1
    • Using a flathead screwdriver (or flat piece of plastic), nudge in the clip holding the shell-side battery terminal in place to release it from the shell.
  5. Nintendo Gameboy Pocket Shell-Side Battery Terminal Corrosion Removal: 5 단계, 이미지 1/2 Nintendo Gameboy Pocket Shell-Side Battery Terminal Corrosion Removal: 5 단계, 이미지 2/2
    • Using a pair of tweezers, remove the battery terminal from the shell.
  6. Nintendo Gameboy Pocket Shell-Side Battery Terminal Corrosion Removal: 6 단계, 이미지 1/2 Nintendo Gameboy Pocket Shell-Side Battery Terminal Corrosion Removal: 6 단계, 이미지 2/2
    • Add isopropyl alcohol to a toothbrush.
    • Spread a paper towel down to keep your workspace clean.
    • Scrub the terminal where the corrosion is to remove as much as possible. If most of the corrosion is removed, skip to step 10.
  7. Nintendo Gameboy Pocket Shell-Side Battery Terminal Corrosion Removal: 7 단계, 이미지 1/1
    • Use the steel wool to remove as much corrosion as possible.
  8. Nintendo Gameboy Pocket Shell-Side Battery Terminal Corrosion Removal: 8 단계, 이미지 1/2 Nintendo Gameboy Pocket Shell-Side Battery Terminal Corrosion Removal: 8 단계, 이미지 2/2
    • Add metal polish to a paper towel.
    • Polish the battery terminal to remove the remainder of the corrosion.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Sarah Travers
회원 가입일: 03/24/21
265 평판
안내서 1개 작성함
UMass Dartmouth, Team S1-G24, Riel Spring 2021 UMass Dartmouth, Team S1-G24, Riel Spring 2021 회원
UMASSD-RIEL-S21S1G24
1 회원
안내서 2개 작성하였습니다
댓글 3개
Thank you for the guide! Resurrected a Gameboy Pocket today that has graphical glitches on the boot screen and sometimes crashed mid-game when a cartridge could load. This process seems to have completely remediated that.
I only needed to complete through step 6 to get clean shiny contacts in my case.
sacratoy - 답글
Much better than the usual battery replacement guides! Most of those are practically useless as they do little more than say, “replace the batteries,” which is pretty much self-evident, and noting, “clean any corrosion,” without explaining how to do that!
Wolf Naegeli - 답글
Is there a corresponding guide for cleaning the sections of the battery terminal which are fixed to the board, i.e. not shell-side?
Samuel Bradley - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 39
30일 전: 196
전체 시간: 5,447
