주요 콘텐츠로 건너뛰기
Nintendo Switch Battery Replacement
필요한 것
  1. Nintendo Switch Battery Replacement, Release the Joy Con controller locking tabs: 1 단계, 이미지 1/3 Nintendo Switch Battery Replacement, Release the Joy Con controller locking tabs: 1 단계, 이미지 2/3 Nintendo Switch Battery Replacement, Release the Joy Con controller locking tabs: 1 단계, 이미지 3/3
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Nintendo Switch Battery Replacement, Remove the Joy Con controllers: 2 단계, 이미지 1/3 Nintendo Switch Battery Replacement, Remove the Joy Con controllers: 2 단계, 이미지 2/3 Nintendo Switch Battery Replacement, Remove the Joy Con controllers: 2 단계, 이미지 3/3
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
  3. Nintendo Switch Battery Replacement, Remove the back-side screws: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
  4. Nintendo Switch Battery Replacement, Remove the top and bottom screws: 4 단계, 이미지 1/2 Nintendo Switch Battery Replacement, Remove the top and bottom screws: 4 단계, 이미지 2/2
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the rear panel:
    • One 2.5 mm-long screw on the top edge of the device
    • Two 2.5 mm-long screws on the bottom edge of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try another JIS 000 or PH 000 driver if the screws won't come out.
  5. Nintendo Switch Battery Replacement: 5 단계, 이미지 1/2 Nintendo Switch Battery Replacement: 5 단계, 이미지 2/2
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
  6. Nintendo Switch Battery Replacement: 6 단계, 이미지 1/2 Nintendo Switch Battery Replacement: 6 단계, 이미지 2/2
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  7. Nintendo Switch Battery Replacement: 7 단계, 이미지 1/1
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the 1.6 mm screw in the kickstand well.
    • Close the kickstand.
  8. Nintendo Switch Battery Replacement: 8 단계, 이미지 1/3 Nintendo Switch Battery Replacement: 8 단계, 이미지 2/3 Nintendo Switch Battery Replacement: 8 단계, 이미지 3/3
    • Open the game card cartridge flap.
    • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
    • Lift the rear panel up from the bottom of the device and remove it.
  9. Nintendo Switch Battery Replacement, Remove the microSD card reader: 9 단계, 이미지 1/1
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the 3.1 mm screw securing the microSD card reader to the device.
  10. Nintendo Switch Battery Replacement: 10 단계, 이미지 1/2 Nintendo Switch Battery Replacement: 10 단계, 이미지 2/2
    • Use your fingers or a pair of tweezers to lift the microSD card reader straight up from the device to disconnect and remove it.
    • During reassembly, make sure the press connector underneath the foam pad is firmly connected to the motherboard. It may help to remove the foam pad before reinstalling the card reader.
  11. Nintendo Switch Battery Replacement, Remove the shield plate: 11 단계, 이미지 1/1
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the six 3 mm screws securing the shield plate to the device.
  12. Nintendo Switch Battery Replacement: 12 단계, 이미지 1/2 Nintendo Switch Battery Replacement: 12 단계, 이미지 2/2
    • Use your fingers or a pair of tweezers to peel back the piece of foam on the top edge of the device near the fan exhaust port.
    • If the foam doesn't easily peel away, don't force it as it might end up tearing. Carefully peel at different spots to pull back the foam.
  13. Nintendo Switch Battery Replacement: 13 단계, 이미지 1/3 Nintendo Switch Battery Replacement: 13 단계, 이미지 2/3 Nintendo Switch Battery Replacement: 13 단계, 이미지 3/3
    • Insert a spudger underneath the shield plate along the edge of the device.
    • Pry up to lift the shield plate and remove it from the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. This helps prevent the Switch from overheating.
    • You can reuse the pink thermal compound if you're careful. Keep the compound clean and make sure it makes solid contact between the heat sink and the shield during reassembly.
    • If you need to replace it, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as K5 Pro, during reassembly.
  14. Nintendo Switch Battery Replacement, Battery: 14 단계, 이미지 1/2 Nintendo Switch Battery Replacement, Battery: 14 단계, 이미지 2/2
    • Insert the pointed end of a spudger underneath the white connector and pry upwards to disconnect the battery from the motherboard.
  15. Nintendo Switch Battery Replacement: 15 단계, 이미지 1/2 Nintendo Switch Battery Replacement: 15 단계, 이미지 2/2
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
    • Do not wear contact lenses without eye protection.
    • Protective gloves are also included in your kit. If you are concerned about possible skin irritation, put your gloves on now.
  16. Nintendo Switch Battery Replacement: 16 단계, 이미지 1/2 Nintendo Switch Battery Replacement: 16 단계, 이미지 2/2
    • Apply a small amount of adhesive remover (approximately 1 ml) evenly along the elevated edge of the battery cell.
    • Wait 2-3 minutes for the liquid adhesive remover to penetrate underneath the battery cell before you proceed to the next step.
  17. Nintendo Switch Battery Replacement: 17 단계, 이미지 1/2 Nintendo Switch Battery Replacement: 17 단계, 이미지 2/2
    • Insert the flat end of a spudger underneath the battery and carefully pry upwards to separate it from the mid-frame.
  18. Nintendo Switch Battery Replacement: 18 단계, 이미지 1/1
    • Remove the battery from the device.
결론
다른 152명이 해당 안내서를 완성하였습니다.
Blake Klein
회원 가입일: 01/29/17
70,531 평판
안내서 50개 작성하였습니다
댓글 50개
Can anyone confirm that Switch will NOT work with the battery removed or dead (dead as in once it’s totally non-functional as all lithium batteries eventually are, not dead as in just discharged but the battery works).
PSP works with the battery dead or pulled, as far as I know DS, 3DS, Vita and Switch do NOT, which is a gigantic design flaw.
Tester - 답글
Yes. The battery of my Switch has been wearing down over some time, to the point where I had to charhe the device for some hours to even activate it - it isn't functional without a working battery.
Helen Winkler -
I would highly recommend against keeping dead batteries in any system, as this can cause damage to the motherboard of the device. If you experience your Switch randomly turning off while its battery is dead, immediately seek to get the battery removed or replaced.
While it is considered rare, dead batteries can sometimes reverse in polarity when its voltage is too low. This can damage the motherboard or other components unexpectedly.
Reboot -
Why can't you reuse the switch's battery?, if I'm just replacing the shell of the switch and have to move the battery why can't I reuse the battery in the new shell?
Matt - 답글
Good question!
For safety reasons, we strongly discourage people from reusing a battery once it has been removed. Bending a lithium-ion battery even slightly can create uneven spots between the thin layers inside the battery. The battery may function fine for awhile, but over time and charge cycles, the uneven area can wear down faster, eventually resulting in an electrical short. The battery would fail, swell up, and possibly catch on fire.
Arthur Shi -
댓글 쓰기
조회 통계:
24 시간 전: 357
7일 전: 2,771
30일 전: 13,823
전체 시간: 745,061
