주요 콘텐츠로 건너뛰기
Nintendo Switch Dock Circuit Board Replacement
필요한 것
  1. Nintendo Switch Dock Circuit Board Replacement, Remove cables and wires: 1 단계, 이미지 1개 중 1개
    • Unclip the back plate. It will fold back to expose the power wire and the HDMI cable.
  2. Nintendo Switch Dock Circuit Board Replacement, Prepare dock for disassembly: 2 단계, 이미지 1개 중 1개
    • Remove the Switch from the dock
    • Orient the dock so that the adapter block faces up like shown
  3. Nintendo Switch Dock Circuit Board Replacement, Removing first set of screws: 3 단계, 이미지 3개 중 1개 Nintendo Switch Dock Circuit Board Replacement, Removing first set of screws: 3 단계, 이미지 3개 중 2개 Nintendo Switch Dock Circuit Board Replacement, Removing first set of screws: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using a Tri-head 360x50 (or Y00) driver, unscrew the four screws shown (1, 2, 3, 4) and use mini-tweezers to remove the screws. These are short.
    • Place the screws in a secure location where you will remember to get them later.
    • If you have an OLED dock, the bottom left screw is hidden under a plastic cover (2nd photo, red). To remove this cover, there's a screw on the bottom (underside) of the dock itself (2nd photo, orange). Remove that first, then you can remove the cover with a pry tool or fingernail, and then you can remove the last Y-screw (3rd photo, orange).
  4. Nintendo Switch Dock Circuit Board Replacement: 4 단계, 이미지 1개 중 1개
    • Using Tri-head 360x50 (or Y00) driver, unscrew the next four screws shown (A, B, C, D) and use the mini-tweezers to remove the screws. These screws will be longer.
    • Place the screws in a secure location.
  5. Nintendo Switch Dock Circuit Board Replacement, Removing the backing: 5 단계, 이미지 2개 중 1개 Nintendo Switch Dock Circuit Board Replacement, Removing the backing: 5 단계, 이미지 2개 중 2개
    • Carefully pull to remove the backing from the switch dock, exposing the circuit board.
  6. Nintendo Switch Dock Circuit Board Replacement, Remove the circuit board: 6 단계, 이미지 1개 중 1개
    • Carefully unplug the red and black cable connecting the circuit board with the dock housing
    • This cable can be more easily removed with a pair of needle-nosed pliers. Clamp on to the plastic casing and gently pull to remove the cable
  7. Nintendo Switch Dock Circuit Board Replacement, Remove the film cable: 7 단계, 이미지 3개 중 1개 Nintendo Switch Dock Circuit Board Replacement, Remove the film cable: 7 단계, 이미지 3개 중 2개 Nintendo Switch Dock Circuit Board Replacement, Remove the film cable: 7 단계, 이미지 3개 중 3개
    • Gently pull the film cable out of the circuit board. The cable should slide free when lightly pulled. Don't pull on it, you're liable to break the cable or connector.
    • Instead, look at the connector itself. There's a flap (second photo) on the top side of the connector. Using a spudger or fingernail (NO METAL - if you tear the cable, nothing will work and you'll be very sad) to pop up that flap. It's a locking mechanism, so there's a bit of resistance.
    • Once you've lifted the flap up, take a note of the orientation of the cable and how it sits in the connector. The cable has two tabs, on one the right and one on the left (marked with a red circle), which align the cable in the connector. Good idea to take a photo at this step for reference later.
    • The cable can then be gently lifted (to get the tabs out of their alignment grooves) and pulled back away from the connector to release it. Close the locking latch so it doesn't break off later.
    • Unpack and inspect replacement circuit board - check for any damage or faults
  8. Nintendo Switch Dock Circuit Board Replacement, Reconnect film cable: 9 단계, 이미지 2개 중 1개 Nintendo Switch Dock Circuit Board Replacement, Reconnect film cable: 9 단계, 이미지 2개 중 2개
    • Carefully reconnect the film cable to the replacement circuit board. The cable should slide in when gentle pressure is applied. Lift the locking flap (see step 7 for images) with a plastic (NO METAL) tool or your fingernail, slide the cable in and make sure the tabs are seated properly before closing the locking latch.
    • Ensure the cable is oriented correctly before insertion to avoid damage.
  9. Nintendo Switch Dock Circuit Board Replacement, Reconnect red/black cable: 10 단계, 이미지 2개 중 1개 Nintendo Switch Dock Circuit Board Replacement, Reconnect red/black cable: 10 단계, 이미지 2개 중 2개
    • Make sure the cable is oriented correctly - you can check the port to make sure the holes will line up correctly
    • Align plug - end of cable to port and apply gentle pressure. The cable should slide back into place.
    • The circuit board should fit without obstruction.
  10. Nintendo Switch Dock Circuit Board Replacement, Reinsert circuit board: 11 단계, 이미지 1개 중 1개
    • Gently apply pressure to the circuit board to ensure it seats into the housing.
  11. Nintendo Switch Dock Circuit Board Replacement, Put backing on: 12 단계, 이미지 1개 중 1개
    • Place backing onto dock. All screw holes should line up.
    • Apply gentle pressure. (You should feel a slight "give" as it seats properly)
  12. Nintendo Switch Dock Circuit Board Replacement, Reinsert screws Part 1: 13 단계, 이미지 1개 중 1개
    • Use Tri-Head driver to reinsert screws (A, B, C, D).
    • These are the longer (6 or 6.5mm) ones.
  13. Nintendo Switch Dock Circuit Board Replacement, Reinsert screws Part 2: 14 단계, 이미지 1개 중 1개
    • Use Tri-head driver to reinsert screws (1, 2, 3, 4).
    • These are the shorter (3mm) ones.
  14. Nintendo Switch Dock Circuit Board Replacement, Reinsert cables: 15 단계, 이미지 1개 중 1개
    • Plug HDMI and power cable into switch dock.
  15. Nintendo Switch Dock Circuit Board Replacement, Connect with an HDMI device: 16 단계, 이미지 1개 중 1개
    • Plug HDMI cable into a device with an HDMI port (TV, monitor, computer, etc.) (NOTE: need adapter for PC for video and audio connection)
  16. Nintendo Switch Dock Circuit Board Replacement, Using the dock Part 1: 17 단계, 이미지 1개 중 1개
    • Insert Nintendo Switch into dock and turn it on.
    • The dock should charge your switch. If it doesn't, check the power supply/power cable
    • When correctly seated in the dock, the Switch screen will remain black
    • Use Switch normally to test audio and video output
    • If Switch works normally but the dock doesn't, check to make sure the following are true:
    • Both cables are plugged in correctly
    • Both cables are not obstructed or damaged
    • Circuit board is not damaged
    • Circuit board seats correctly into housing
결론
All electrical equipment should be stored safely out of the way of hazards. After replacement, the Switch Dock should function properly.
다른 13명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
[deleted]
회원 가입일: 11/23/21
630 평판
안내서 1개를 작성함
6가이드 댓글
At https://www.hollywood-docks.com, we specialize in new dock installations, existing dock repairs and updates, seawall installations and repairs, deck and patio construction, and much more. We pride ourselves on providing high-quality craftsmanship and exceptional customer service.
Paul Walker - 답글
Wrong kind of dock, bro.
modtang -
Conecta el cable HDMI a un dispositivo con un puerto HDMI
Vlad Luk - 답글
Enchufa el HDMI y el cable de alimentación en la base de la Switch.
Vlad Luk -
had a bad surge and now dock isn't working (but the power cord will charge the switch directly)
how do I tell if it is the circuit board or the USBC board that is bad?
Jeff - 답글
댓글 쓰기
조회 통계:
지난 24시간: 29
지난 7일: 205
지난 30일: 873
전체 시간: 42,161
