주요 콘텐츠로 건너뛰기
Nintendo Switch Lite Left Speaker Replacement
필요한 것
    • Before beginning this repair, make sure that the device is completely turned off.
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
  1. Nintendo Switch Lite Left Speaker Replacement, Remove the top and bottom back panel screws: 2 단계, 이미지 1/2 Nintendo Switch Lite Left Speaker Replacement, Remove the top and bottom back panel screws: 2 단계, 이미지 2/2
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the back panel:
    • Two 3.6 mm-long screws on the top of the device
    • Two 3.6 mm-long screws on the bottom of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
  2. Nintendo Switch Lite Left Speaker Replacement, Release the clips securing the back panel: 3 단계, 이미지 1/2 Nintendo Switch Lite Left Speaker Replacement, Release the clips securing the back panel: 3 단계, 이미지 2/2
    • Insert an opening tool into the left speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips securing the back panel.
    • Avoid inserting the opening tool further than required to prevent damage to the speaker module.
  3. Nintendo Switch Lite Left Speaker Replacement, Continue releasing the clips around the device: 4 단계, 이미지 1/2 Nintendo Switch Lite Left Speaker Replacement, Continue releasing the clips around the device: 4 단계, 이미지 2/2
    • Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
  4. Nintendo Switch Lite Left Speaker Replacement, Twist to release the clips: 5 단계, 이미지 1/2 Nintendo Switch Lite Left Speaker Replacement, Twist to release the clips: 5 단계, 이미지 2/2
    • Insert an opening tool into the right speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips.
  5. Nintendo Switch Lite Left Speaker Replacement, Slide and pry around the corners: 6 단계, 이미지 1/2 Nintendo Switch Lite Left Speaker Replacement, Slide and pry around the corners: 6 단계, 이미지 2/2
    • Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
  6. Nintendo Switch Lite Left Speaker Replacement: 7 단계, 이미지 1/2 Nintendo Switch Lite Left Speaker Replacement: 7 단계, 이미지 2/2
    • Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
  7. Nintendo Switch Lite Left Speaker Replacement, Remove the back panel: 8 단계, 이미지 1/3 Nintendo Switch Lite Left Speaker Replacement, Remove the back panel: 8 단계, 이미지 2/3 Nintendo Switch Lite Left Speaker Replacement, Remove the back panel: 8 단계, 이미지 3/3
    • Lift the bottom edge of the back panel, opening it like a book.
    • Remove the back panel.
  8. Nintendo Switch Lite Left Speaker Replacement, Remove the shield plate: 9 단계, 이미지 1/1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following four screws:
    • Three 3.1 mm screws
    • One 4.5 mm screw
  9. Nintendo Switch Lite Left Speaker Replacement: 10 단계, 이미지 1/3 Nintendo Switch Lite Left Speaker Replacement: 10 단계, 이미지 2/3 Nintendo Switch Lite Left Speaker Replacement: 10 단계, 이미지 3/3
    • Use a spudger or your fingers to lift the shield plate up and out of the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • Clean off the old thermal paste from the shield plate and heat sink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the heat sink before reassembly.
  10. Nintendo Switch Lite Left Speaker Replacement, Disconnect the battery: 11 단계, 이미지 1/2 Nintendo Switch Lite Left Speaker Replacement, Disconnect the battery: 11 단계, 이미지 2/2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
  11. Nintendo Switch Lite Left Speaker Replacement: 12 단계, 이미지 1/2 Nintendo Switch Lite Left Speaker Replacement: 12 단계, 이미지 2/2
    • Use a pair of tweezers to slide the interconnect cable out of its connector on the motherboard.
  12. Nintendo Switch Lite Left Speaker Replacement: 13 단계, 이미지 1/2 Nintendo Switch Lite Left Speaker Replacement: 13 단계, 이미지 2/2
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
  13. Nintendo Switch Lite Left Speaker Replacement, Remove the left speaker: 14 단계, 이미지 1/2 Nintendo Switch Lite Left Speaker Replacement, Remove the left speaker: 14 단계, 이미지 2/2
    • Use a pair of tweezers or your fingers to pull the left speaker cable straight up and out of its socket on the daughterboard.
    • Do not pull from the wires, or else you risk ripping the wires off the connector.
  14. Nintendo Switch Lite Left Speaker Replacement: 15 단계, 이미지 1/1
    • Three 2.5 mm screws
    • One 4.5 mm screw
  15. Nintendo Switch Lite Left Speaker Replacement: 16 단계, 이미지 1/2 Nintendo Switch Lite Left Speaker Replacement: 16 단계, 이미지 2/2
    • Use your fingers to lift and remove the left speaker module cover.
  16. Nintendo Switch Lite Left Speaker Replacement: 17 단계, 이미지 1/3 Nintendo Switch Lite Left Speaker Replacement: 17 단계, 이미지 2/3 Nintendo Switch Lite Left Speaker Replacement: 17 단계, 이미지 3/3
    • Insert a spudger into the gap at the top of the speaker.
    • Take care to avoid the speaker wires as you insert the spudger into the gap.
    • Pry the speaker up to lift it out of its recess.
    • The speaker is adhered with light adhesive inside the speaker module, so a bit of force is required.
    • Remove the left speaker.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
다른 2명이 해당 안내서를 완성하였습니다.
Craig Lloyd
회원 가입일: 02/10/16
30,829 평판
안내서 82개 작성하였습니다
댓글 한 개
Est-ce que les haut parleur des la switch classique et de la lite son pareil et compatible ?
thomasdupin23 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 14
30일 전: 99
전체 시간: 2,103
