주요 콘텐츠로 건너뛰기
Nintendo Switch Rear Panel Replacement
필요한 것
  1. Nintendo Switch Rear Panel Replacement, Rear Panel: 1 단계, 이미지 1/1
    • Remove the four 6.3mm Tri-point Y00 screws from the rear panel.
  2. Nintendo Switch Rear Panel Replacement: 2 단계, 이미지 1/1
    • Remove the single 6.1mm JIS #000 screw from underneath the kickstand.
  3. Nintendo Switch Rear Panel Replacement: 3 단계, 이미지 1/1
    • Remove the two 2.7mm JIS #000 screws from the bottom of the device.
  4. Nintendo Switch Rear Panel Replacement: 4 단계, 이미지 1/1
    • Remove the single 2.7mm JIS #000 screw from the top of the device.
  5. Nintendo Switch Rear Panel Replacement: 5 단계, 이미지 1/2 Nintendo Switch Rear Panel Replacement: 5 단계, 이미지 2/2
    • Remove the single 3.8mm JIS #0 screw from the right Joy-Con rail.
    • Remove the single 3.8mm JIS #0 screw from the left Joy-Con rail.
  6. Nintendo Switch Rear Panel Replacement: 6 단계, 이미지 1/3 Nintendo Switch Rear Panel Replacement: 6 단계, 이미지 2/3 Nintendo Switch Rear Panel Replacement: 6 단계, 이미지 3/3
    • Pull the rear panel up and off of the device.
결론
다른 75명이 해당 안내서를 완성하였습니다.
Blake Klein
회원 가입일: 01/29/17
70,531 평판
안내서 50개 작성하였습니다
댓글 10개
Excellent and concise guide.
The new panel doesn’t come with the sticky grille pieces x 2 on the bottom. Is it supposed to be a straight transfer between the old and the new?
fclbriat123 - 답글
You can transfer the grill to the new back plat
Phillip Norton -
Just did this replacement and there are a few things to keep in mind that this review does not mention. There are x2 square foam pieces that can be transferred to the new panel located at the bottom backside of the old. Also, the game cartridge shield hardware and the kickstand holder hardware have to be taken off the back of the old panel and transferred to the new panel. The kickstand has 2 Phillips #000 screws and the game cartridge shield has 1 Phillips #000 screw
Ryan Talbert - 답글
How do you transfer the foam pieces? Use some heat to loosen their adhesive and then remove them and transfer over the new backplate?
John - 답글
Is the casing the same between the HAC model and the HAD model? This guide doesn’t specify
Julian Webb - 답글
댓글 쓰기
조회 통계:
24 시간 전: 49
7일 전: 340
30일 전: 1,549
전체 시간: 91,717
